Hypersurfaces of R^n are Orientable
  • Context: Graduate
  • Thread starter Thread starter WWGD
Every closed hypersurface of R^n, specifically any closed (n-1)-submanifold, is orientable. This conclusion is supported by examining the cohomology of the pair (T, N), where T is a tubular neighborhood and N is its boundary. The discussion highlights the role of Alexander duality in proving that if the compact smooth manifold M is non-orientable, the resulting homology groups lead to contradictions. The participants also reference Milnor's Characteristic Classes and the implications of the Jordan Curve Theorem in relation to duality.
  • Understanding of homology and cohomology in algebraic topology
  • Familiarity with Alexander duality and its applications
  • Knowledge of tubular neighborhoods and their properties
  • Basic concepts of smooth manifolds and their embeddings
  • Study the Alexander Duality theorem in detail
  • Explore Milnor's Characteristic Classes for deeper insights
  • Learn about excision in homology and its implications
  • Investigate the relationship between Jordan Curve Theorem and duality
Mathematicians, particularly those specializing in algebraic topology, differential geometry, and manifold theory, will benefit from this discussion. It is also relevant for students and researchers looking to understand the orientability of hypersurfaces and the application of duality in topology.
WWGD
Anyone know how to prove the result that every closed hypersurface of ## \mathbb R^n ## , i.e., any closed (n-1)-submanifold of ## \mathbb R^n ## is orientable? Note that if we assume this is true, this shows ## \mathbb RP^n ## cannot be embedded in ## \mathbb R^{n+1} ##
EDIT: there is a result that every hypersurface can be represented as ## f^{-1}(0)## , where I think ##f## is at least an immersion. I heard this has to see too with Alexander duality but I don't see clearly where this duality comes into place, though.
Correct this if it s wrong but I think it works.
If the compact smooth manifold ##M ## is embedded in ## R^{n+1}## then it has a tubular neighborhood, ## T ## ,with boundary another compact manifold,N.
The Z cohomology of the pair ## (T,N) ## is equal to the cohomology of ##S^{n+1}## since ##S^{n+1}## is homeomorphic to the Thom space of the normal bundle of ##M## in ## R^{n+1}##. This is proved using Excision.
The exact homology of the pair, (T,N), is
## 0 ← H^{n+1}(S^n) ← H^n(N) ← H^n(M) ← H^n(S^{n+1}) ← ... ##
which is ## 0 ← Z ← H^n(N) ← H^n(M) ← 0 ← ... ##
If ##M## is non orientable then ## N ## is connected so that ##H^n(N)## is equal to ##Z## and ##H^n(M)## is equal to ## Z_{2}##
So the exact sequence is
## 0 ← Z ← Z ← Z_{2} ← 0 ← ... ##
which is impossible.
If ##M## is orientable then ## N ## has two diffeomorphic components so that ##H^n(N## is equal to ##Z ⊕ Z## and ##H^n(M)## is equal to ## Z##
## 0 ← Z ← Z ⊕Z← Z← 0 ← ... ##
which is possible.
Can you see why/how Alexander duality plays a role here? Sorry, I don't understand enough about Thom spaces to understand the answer. I am aware of excision and the LES associated to it, and I understand the argument otherwise, but maybe if you can see where/if Alexander duality is applied?
I don't really know the Alexander Duality theorem but here is a simplified version that is given as an exercise in Milnor's Characteristic Classes that answers your question.
BTW: I would be happy to learn the proof with you.
If K is a compact subset of the sphere, ##S^n## that is a retract of some neighborhood in ##S^n## then using ordinary homology, there is an isomorphism between
## H^{i-1}(K,x) ## and ## H_{n-i}(S^n - K,y)## where ##x## is a point of ##K## and ##y## is a point of ##S^n-K##
An embedded compact smooth submanifold is a retract of a tubular neighborhood so the conditions are satisfied.
If ## i - 1 = n - 1 ## as in the case of a hyper-surface the isomorphism says
## H^{n-1}(K,x) ## and ## H_{0}(S^n - K,y)## are isomorphic.
But ##H_{0}(S^n - K,y)## is a direct sum of one less than the number of connected components of ## S^n-K## copies of ##Z##
Since ##H^{n-1}(K,x) ## is not zero the number of connected components must be greater than one so ## H_{0}(S^n - K,y)## is not the zero group but is a direct sum of at least one copy of ##Z##..
But if ##K## is non orientable its top cohomology is ##Z_{2}## and so can not be isomorphic to a torsion free group.
Nice, thanks. Sure, we can agree to read the proof together. My situation is a bit uncertain at this point, if you can be flexible, I would be glad to work it out with you. BTW, I read that Alexander Duality is a generalization of the Jordan
Curve thm., in that it deals with the topology of complementary subspaces ( with complementary meaning their union is the whole space). A.De studies the homological properties of complementary subspaces. The homological properties of a set can be defined in terms of those in the complement
...http://www.encyclopediaofmath.org/index.php/Alexander_duality
I am completely flexible. The Alexander Duality theorem does seem to generalize the Jordan curve theorem since for hypersurfaces of the sphere it says that the sphere is divided into at least two components. I wonder if the sphere is not special and that the theorem works for any simply connected manifold. I wonder this because the first proof I gave using tubular neighborhoods needed only that the sphere be simply connected (and also orientable).
Pick a source for the proof that we can read together
  • · Replies 38 ·
  • · Replies 36 ·
