I am trying to figure out how to refer to two overlapping uncertainty
This discussion centers on interpreting overlapping uncertainty results in experimental data, specifically regarding golf balls rated 72 and 98. The power transfer ratios are 1.482 (±0.197) for the 72 rated ball and 1.343 (±0.287) for the 98 rated ball. The conclusion drawn is that the overlap in uncertainty makes it inconclusive whether the type of golf ball affects the power transfer ratio. A definitive conclusion requires non-overlapping uncertainties.
  • Understanding of statistical uncertainty and confidence intervals
  • Familiarity with experimental design and hypothesis testing
  • Knowledge of power transfer ratio in physics or engineering contexts
  • Basic proficiency in interpreting scientific data and results
  • Research statistical methods for analyzing overlapping confidence intervals
  • Study hypothesis testing techniques in experimental design
  • Learn about the implications of uncertainty in scientific conclusions
  • Explore case studies on power transfer ratios in sports equipment
Researchers, data analysts, and students in fields such as physics, engineering, and sports science who are dealing with experimental data and uncertainty analysis.
golfz
I am trying to figure out how to refer to two overlapping uncertainty results. I have to write a conclusion and I find it difficult to explain. Even now it may seem unclear as to what I am referring to so I will provide an example. This is directly from my conclusion.
'The 72 rated golf ball had a higher power transfer ratio of 1.482 (±0.197) and that of the 98 rated ball had a ratio of 1.343 (±0.287).'
The two results 'overlap'. How do I refer to this? These are two different results for two difference independent variables.
It depends on the initial hypothesis you are trying to test.
Assuming you are testing the effect of ball type on power transfer ratio, the proper conclusion in this instance is that it is inconclusive whether the type of golf ball affects the power transfer ratio. A conclusive result would require the uncertainties to not overlap.
I would avoid saying whether one ball has a higher power transfer ratio over the other for this reason. The truth is, you cannot definitively say which is higher.
Claude.
  • · Replies 21 ·
  • · Replies 18 ·
  • · Replies 19 ·
