I do not why the particle does the simple harmonic motion.
The discussion revolves around understanding the conditions under which a particle exhibits simple harmonic motion, particularly focusing on the behavior of a variable \( r \) that is expected to decrease over time. Participants are exploring the mathematical relationships involved, including the implications of coefficients in exponential terms.
  • Participants are questioning the nature of the equation provided and whether it represents harmonic motion. They discuss the need to derive the acceleration of the particle and how to express \( r \) in terms of exponential functions. There are inquiries about the conditions under which \( r \) can continually decrease, including the roles of coefficients \( A \) and \( B \).
The conversation is ongoing, with various interpretations being explored regarding the coefficients of the exponential terms. Some participants are providing guidance on how to combine these terms to ensure that the function decreases over time without becoming negative. There is a recognition of the need to clarify the roles of \( A \) and \( B \) in the context of the problem.
Participants are navigating assumptions about the signs and values of coefficients in the equations, particularly under the constraint that \( r \) must remain non-negative. There is a focus on the implications of these assumptions for the behavior of the system as time progresses.
xiaozegu
I do not why the particle does the simple harmonic motion. And how to find such innitial condition to satify r decreases continually in time.
3. The Attempt at a Solution [/b
Is it need to take derivative of r?
The equation given is NOT one of harmonic motion. It contains exponential non-periodic terms.
As for how to obtain the equation, recall the formula for acceleration in circular motion.
Is it a resistance force? If not, how can r decrease?
Before you can answer the question "how can r decrease", you must obtain the acceleration of the particle.
So it needs A+B<0?
xiaozegu said:
So it needs A+B<0?
Assuming γ>0 (which you can, without loss of generality), how do the individual terms e-γt and e+γt vary as t increases? How could you make a linear combination of them that always decreases?
I can get Be2γt>A
xiaozegu said:
I can get Be2γt>A
Do you mean that for any A and B the above will be true for all sufficiently large t? Not so.
If that's not what you meant, what do you mean?
Please answer the specific questions I asked before: how does each of the two terms change as t increases?
If γ >0, e-γt decreases as time goes up, e+γt increase. So I need find the derivative of these two items make de+γt/dt>de-γt/dt?
No, you need to find a linear combination of e+γt and e-γt, i.e. something of the form Ae+γt + Be-γt, which decreases (without going negative) as t increases. You have correctly worked out that e-γt does that. There's a very easy solution for A and B.
If B is negative, is it OK?
With A being what? If A > 0, what will happen as t increases (regardless of B)? If A < 0 what will happen?
So it needs A>0,B<0?
Instead of firing off guesses, please try to answer my questions: If A > 0, what will happen as t increases (regardless of B)? If A < 0 what will happen?
If A>0, r will decrease as time, If A<0, r will increase as time.
We may be at cross purposes here. In my posts I have A as the coefficient for the +γ term and B as that for the -γ term. Do you have it the other way around?
Anyway, what I'm trying to steer you to is that if A > 0 then Ae+γt will tend to +∞ as t→+∞, and completely dominate over the e-γt term, making it irrelevant (regardless of the value of B). Can you see that?
Conversely, if A < 0 then Ae+γt will tend to -∞ as t→+∞, again completely dominating the e-γt term, making it irrelevant.
So if you need the function to decrease as t→+∞ but without going negative, what does that leave as a possible value for A?
I think it is A>0 and A>B
No, if A>0 then Ae+γt+Be-γt →+∞ as t→+∞, for all B. So we can absolutely rule out A>0.
Similarly, if A<0 then Ae+γt+Be-γt →-∞ as t→+∞, for all B. So we can absolutely rule out A<0.
What is left?
What is left?
A equals to zero. Because r cannot be negative, so A cannot <0. Plus, B>0.
xiaozegu said:
A equals to zero.
Yes!
haruspex said:
Yes!
thank you very much
  • · Replies 51 ·
