I have problems with differentiating
  • Thread starter Thread starter Altami
    Differentiating
11 replies · 2K views
Altami
Differentiate.
y=x^2 + 4x +3/(square root x)
and
H(x)=(x+x^-1)^3
For the first one I got x^3/2 + 4x^1/2 + 3x^-1/2
But I don't know if that is correct or where to go from here?
The second I really don't know what to do, I am not sure if I have to distribute the exponent 3 throughout the parenthesis? I really don't know what to do, if someone could give me a hint? Then I could work it out. A friend of mine got x^3 + 3x^2(x^-1) + 3x(x^-2) + x^-3. But I don't know how he got that? Could someone explain if he is right or how he got that?
Thanks.
Altami said:
Differentiate.
and
H(x)=(x+x^-1)^3
Thanks.
Your answer to the first one is not correct. You need to differentiate x^2, 4x and 3/x^(1/2) independently and then add the stuff together. To find the derivative of 3/(x^(1/2)), it is easier to write it this way: 3x^(-1/2).
As for the second one, I haven't worked it out, but you have two options for how to do this 1)write it as: (x+x^-1)(x+x^-1)(x+x^-1) and find the derivative (this is going to get ugly)
2)Use the chain rule
There's another option on the third one: expand it and then take the derivative. The cube of a binomial isn't too hard.
(a + b)3 = a3 + 3a2b + 3ab2 + b3.
You can apply this formula to (x + 1/x)3. After expansion, just take the derivative of the four terms.
Ahh yes, Mark's way is better.
Okay let me try it and I'll show my answer hopefully I'll get the right one, thanks guys.
Okay for the second one I got
H'(x)=3x^2 + 3 - 3x^-2 - 3x^-4...right?
And for the first one I got
3/2x^1/2 + 2x^-1/2 - -3/2x^-3/2
Yes, right.
I don't know. This is what you wrote:
From your work, it looks like you meant this.
[tex]y = \frac{x^2 + 4x + 3}{\sqrt{x}}[/tex]
If you intended that all three terms should be in the numerator, put parentheses around the entire numerator, like this: y = (x2 + 4x + 3)/x1/2
So which was your problem?
Also, exponents that consist of more than a single digit, use parentheses, as in x^(1/2), x^(-1/2), and so on.
Mark44 said:
Yes, right.
Oh sorry, yea it is...[tex]y = \frac{x^2 + 4x + 3}{\sqrt{x}}[/tex]
The first two terms in your answer are correct, but the third one isn't.
That part of your answer is also ambiguous.
3/2x^-3/2
Does this mean
[tex]\frac{3}{2x^{-3/2}}[/tex]
or
[tex]\frac{3}{2}x^{-3/2}[/tex]
3/2x^-3/2
Does this mean
or
Sorry I need to start using the Latex I know...
It's not really that hard (LaTeX). You can click an expression built from LaTeX to see how it was coded.
Yea I actually downloaded the PDF, just that I haven't come on these boards in a while and I kind of forget the coding...:redface:, but thanks for your help.
Unless you'll be asking a few questions, for the one time off you don't need to learn LaTeX. Just be sure to use brackets as you would have done in the older calculators.
For example, rather than 3/2x^-3/2 you should be writing (3/2)x^(-3/2).
Back to your questions, for y=(x^2 + 4x +3)/sqrt(x) you can split this up into y=x^2/sqrt(x)+4x/sqrt(x)+3/sqrt(x) and change the powers of x accordingly, then differentiate.
For the second question, the chain rule would be easiest imo. Expanding can be done too, but it leaves more room for errors to be made and you'll probably be given higher powers in your exams and expanding will just be out of the question - so it's best if you become sufficient at using the chain rule now.
