I made an N-body simulation program
The forum discussion centers on a user-developed N-body simulation program that initially addressed the 3-body gravity problem through numerical integration. The program evolved to incorporate both electromagnetic and gravitational interactions, utilizing special relativistic mechanics as an approximation under the weak field limit. The simulation allows for complex scenarios, such as modeling a hydrogen atom influenced by a hypothetical microscopic black hole. Users are encouraged to explore the program and provide feedback.
  • Understanding of N-body simulations
  • Familiarity with numerical integration techniques
  • Knowledge of special relativistic mechanics
  • Basic concepts of electromagnetic interactions
  • Explore advanced numerical integration methods for N-body simulations
  • Learn about gravitational interactions in special relativity
  • Investigate the Open Source Physics library for Java simulations
  • Research the implications of general relativity on N-body problems
Physics enthusiasts, programmers interested in simulation development, and researchers exploring gravitational and electromagnetic interactions in N-body systems.
Random Physics Fan
My little project - 3body simulator started as a programming exercise, which I attempted to make a program that solves the famous 3-body gravity problem using numerical integration.
Later I gained interest in the underlying physics and expanded the program to solve N-body problems involving both electromagnetic and gravitational interactions. I also replaced Newtonian mechanics with special relativistic mechanics (as for the model of gravity, general relativity is too challenging for me, so I used an approximation under the weak field limit which was Lorentz-invariant).
You can do all sorts of weird simulation such as the following:
Object 1 (e-) and object 2 (p+) form a hydrogen atom under the classical Bohr's model, with n = 10; object 3 is a hypothetical microscopic blackhole with the mass of the Moon, placed 10 mm under the hydrogen atom.
Object 1:
mass: 9.11e-31 / charge: -1.60e-19
position: 5.29e-9,0,0 / velocity: 0,218500,0
Object 2:
mass: 1.67e-27 / charge: 1.60e-19
position: 0,0,0 / velocity: 0,0,0
Object 3:
mass: 7.35e22 / charge: 0
position: 0,0,-0.01 / velocity: 0,0,0
Duration of simulation: 1e-12 / number of steps: 1000
-> Use advanced option and turn on scientific notation (to show the position of the electron)
(Note: the Schwarzschild radius of the blackhole is about 0.11mm (<<10mm), so general relativistic effects like gravitational time dilation are insignificant.)
Please try out my little program and you comments are appreciated!
Hi,
Congratulation. I did an N-body simulation (yours is N=3) some time ago. It is really not easy nor it is dead, in my eyes. Perhaps you are interested in the following material: N-Body
Have fun!
Great work @Random Physics Fan and @Omega0
While I can't comment on the accuracy of your simulations, from a programming standpoint, I'm sure others can benefit from what you folks did.
As an aside, there are also some good simulations at the Open Source Physics website done in Java using the OSP library of simulation routines.
www.compadre.org/osp
And with that said, its a good time to close this thread.
Jedi
  • · Replies 17 ·
