I need the normal force, the force of friction, and her acceleration
This discussion focuses on calculating the normal force, force of friction, and acceleration for two physics problems involving forces acting on a crate and a ski jumper. In the first problem, a 32 kg crate is pushed with an 800 N force at a 37-degree angle, resulting in a normal force of approximately 531.7 N and an acceleration of 2 m/s². The second problem involves an 80 kg ski jumper on a 37-degree slope, where the normal force is calculated to be 325 N and the force of friction is 70.4 N. The participants emphasize the importance of using free body diagrams and Newton's second law for accurate calculations.
  • Understanding of Newton's second law (Net Force = ma)
  • Knowledge of free body diagrams for visualizing forces
  • Familiarity with the coefficient of friction and its application
  • Basic trigonometry, specifically SOH CAH TOA for resolving forces
  • Study the application of Newton's second law in various scenarios
  • Learn how to effectively draw and interpret free body diagrams
  • Research the effects of different coefficients of friction on motion
  • Explore advanced topics in dynamics, such as inclined planes and frictional forces
Students studying physics, educators teaching mechanics, and anyone interested in understanding forces and motion in real-world applications.
sheebajenny
I've got 2 problems:
Number 1: Greg is pushing a 32 kg crate across the floor. He is making like difficult by applying his 800 N force down at an angle of 37 degrees below the horizontal. The coefficient of kinetic friction between the crate and the floor is .50.
I need to find the normal force, and the acceleration.
Number 2: After completing her jump, a ski jumper is going back up a hill on the other side, which is designed to slow her down. The hill is angled at 37 degrees to the horizontal. The coefficient of kinetic friction between her bargain basement skis and the snow is .20. Her mass, including all equipment, is 80kg
I need the normal force, the force of friction, and her acceleration:cry:
Welcome to the PF, Jenny. One of the rules here is that you have to show us some of your work in order for us to help you. What can you tell us about frictional forces? What direction do they act in? What is the equation relating a force F to an object's mass and its resulting acceleration?
here is what I know force of friction=coefficient of friction*Normal force. To find normal force you use SOH CAH TOA depending. They act opposing the force of in the first problem 800N. g*sin(theda)-acceleration/g*cos(theda) acceleration= 2*distance/time squared. I'm really having a difficult time understanding the whole tension concept with friction thrown in. By themselves I can somewhat understand, but when they are combined I got lost.
I may have figured it our #1 normal force sin37=320/N N=531.7
acceleration .5=10sin37-a/10cos37 a=2m/s*s with major rounding
#2 normal force= 800N? force of friction=160N? acceleration .2=10sin37-a/10cos37 a=-4.4m/s*s
Hi Sheebajenny,
I find drawing a freebody diagram makes life much simpler. Have you done that?
Once you've done that, you can find the net forces in the horizontal and vertical direction.
One hint: the equation you gave, a = 2d/t^2, probably won't be that useful in this problem. Consider using Newton's second law:
Net Force = ma
Where Net force is the sum of all the forces in a certain direction.
Try this, and let us know if you run up against more problems.
Dorothy
I did draw free body diagrams. For the second problem my only force I have is weight it seems like I must be missing something.
correction then I first found acceleration and then I used that to find normal force and then force of friction for the second problem one so I got normal force=325N and force of friction as 70.4N
Are you using g=10 m/s^2?
This is a good try, but I don't think it's quite right yet.
The normal force would be a combination of the downward part of the push and the pull of gravity on the crate.
If you draw a free body diagram, you'll see the normal force pushes up, from the floor, and the other forces (or the components) are straight down. Since there is no motion, they add up to zero:
N - ForceFromPush - ForceFromGravity = 0
Try that, and see what you get.
Dorothy
Yes I'm using 10m/s*s for gravity
I truly understand now, thank you very much for your help I had trouble with this one since the day before Thanksgiving. I really appreciate the help.
Sadie
Could we focus on one problem at a time :confused:
This normal force is much too low for an 80 kg weight on a 37 degree slope.
I'll help you with both, but just one at a time, please.
  • · Replies 20 ·
  • · Replies 16 ·
