I wonder, how deep attack nuclear sub can dive?
  • Thread starter Thread starter Chitose
    Nuclear
Attack nuclear submarines can dive to depths exceeding 1,000 meters, with some reports suggesting maximum depths around 1,400 meters. However, operational torpedoes are generally limited to firing at depths of 400 to 800 meters due to design constraints. The term 'test depth' is used by the Navy to denote the maximum safe operational depth, beyond which submarines require inspection for hull integrity. Endurance for these submarines is primarily limited by food supply, allowing for underwater operation of 6 to 9 months, while reactors are typically fueled for over 20 years.
  • Understanding of submarine operational depths and classifications
  • Knowledge of torpedo specifications and limitations
  • Familiarity with submarine reactor systems and air supply methods
  • Awareness of military classification and information security
  • Research the specifications of the Virginia-class submarine
  • Learn about the electrolysis process used for air production in submarines
  • Investigate the concept of 'test depth' in military submarines
  • Explore the psychological effects of long-term underwater deployments on submarine crews
Military enthusiasts, naval engineers, submarine operators, and anyone interested in the operational capabilities and limitations of attack nuclear submarines.
Chitose
As a topic, how deep attack nucler submerine can dive?
My friend says 1,000 metre, Is Atk sub these day can really dive that deep?
If true, can it fire torpidoes in that deep level?
http://en.wikipedia.org/wiki/Submarines
It appears, the deepest is about 1400m
I only found one torpedo that can be used at 800m so far, others are limited to about 400m. I'm not sure of the limitations of actually firing one, but that is the design depth before the torpedo is crushed.
Real numbers are classified, but the term used in the Navy for the maximum safe depth is 'test depth'. You never want to exceed test depth. Not necessarily because of safety reasons since they add a considerable safety buffer, but due to the boat then needing to be dry docked and out of commission so you can check the hull for integrity.
I see, military classified.
But for a war machine that can dive >1,000m, If their found enemy ship at same depth, They just have to say 'hi' because no one can attack with torpedo in that deep.
and I guess nobody want to try reach maximum deep with ship that cost hundred million dollars.
It's probably more that it gives you an extra place to hide in order to either avoid the enemy or sneak up on them
you could ram the other sub :devil: but that would probably be a little 'kamikaze'. Oh, and try 2.8 billion dollars...
http://en.wikipedia.org/wiki/Virginia_class_submarine
All the way to the bottom!
Or search for underwater aliens...:biggrin:
:smile: 555 Nice one.
Have you ever read Silent Service? one nuclear sub can stand against entire US Pacific fleet. Almost impossible but when I look in their strategy it might be possible.
Okay, back on track.
Assuming that they have unlimited food and water supply, How long attack nuclear submerine can operate individuality?
And how long they can dive without going up to surface? (Air supply per one dive)
Or another classified?
I imagine it would have to do with how long the can scrub air.
CS
Chitose said:
:Assuming that they have unlimited food and water supply, How long attack nuclear submerine can operate individuality?
The reactors are generally fueled for the life of the boat >20years
They make their own air from electrolysis of sea water and fresh water in the same way.
The limit on endurance is set by the amount of food carried (about 6-9 months)
Can't neglect the sanity of the crew. Used to be US subs had 2 crews, Each did 3months under water and 3 months up. Even at that, I swear all bubbleheads who did more than 1 or 2 cruises were permanently warped.
The Royal Navy solution is to have the bases at Portsmouth and Glasgow - as an alternative to visiting these, spending 3 months in a metal tube under the north Atlantic looks pretty good.
Let me just add that any interesting performance specs for military subs are going to be classified, so it's a waste of time to ask for them. Most of the people on here won't know and those that do are not allowed to say. You might as well say, "Hey, I'm looking for classified info. Can anyone help?"
When I worked for General Physics, most of the people in my department were ex-Navy sub guys. I got pretty close to a couple of them, including the guy who was assigned as my project manager. About the only thing I could find out about their deployments was that they were deployed practically without notice, and that until they were under water (and maybe not even then) nobody on the sub knew how long they would be gone. Could be a short deployment to shake down some new equipment - could be months and months. It takes strong cohesive families to make that work, and most of those guys were REAL family-men.
We were in some really high-pressure environments, working under deadlines to produce for some of the top industrial companies in the US, and never once did any of the ex-sub guys raise their voice, even when things were going very poorly (failure of a high-speed in-house printing system, etc) that might threaten our contracts. A very stable bunch of dudes.
I could tell you, but then I'd have to kill you.
Seriously though, I do remember a story about a sub I think LA class, which had it's depth gauge inadvertently isolated for a tagout. As the story goes, they started having deck-plate bolts sheer off and ping around the engine room when the lower level watch asked the Watch Supervisor why his seawater pump suction readings were so high out of spec. They asked the Engineering Officer of the Watch what the depth was, he responded that they were still at periscope depth. A few minutes later when they finally unisolated their depth instruments they were unpleasantly surprised and did an emergency blow, followed by changing pants. When they got to the surface the outside of the boat looked like an accordion because of where the skin had bowed in between the ribs.
Don't know if it's true, but it's very likely. There is a difference between how deep can it go and how deep it can go once.
Oh and Vanadium, I think the OP meant how deep can it go and return from. Surface ships are also known to be able to dive to the bottom, although for some reason that isn't a selling feature.
It doesn't sound likely to me. Especially the part about watch officer stating they are all the time at the periscope depth. When submarine dives its hull is squeezed by the pressure and makes strange sounds - so while the crew that doesn't have access to depth gauge doesn't know what depth they are at, they can hear depth changing.
Well, while it's true submarines do make strange sounds while submerging if the boat slowly crept down over the course of a week it could have been so gentle it was overlooked. If they started out near neutral buoyancy and went down at a fraction of a foot per minute then it could all add up so slowly the boat just settled into place. Remember nuclear subs are underwater continuously for patrols and only change depth when required.
Do you really think people in command of multibillion attack subs are that stupid?
Besides, they don't drift aimlessly for weeks. They have to change their course to be aware of what is going on around the ship (hydrophones have a directional characteristic and subs are better at knowing what they have in front than what they have in back). They have to change depth to check what is going on on the other side of the thermocline.
The story just don't hold water. I can imagine that malfunctioning depth gauge made them think they are at different depth during manoeuvres, but that the sub went to some insane depth and no one have noticed anything sounds off.
I'm an ex-US Submarine officer. So, I happen to know these numbers. But can't say. Read Tom Clancy. He's pretty close.
Chayced's story is a non-starter for many, many reasons. Urban myth.
Maintaining depth requires continuous control. It isn't a stable equilibrium.
it's depth gauge
What idiot would build a sub with one depth gauge?
I'm not buying it either.
This guy!
http://130.94.182.150/subphoto.jpg
I all live in a yellow submarine, a yellow...
Space was at a premium I suppose.
From the picture it is hard to tell how many depth gauges are inside.
dotman said:
This guy!
Where did you get that photo from? I think I recognize the boy behind the sub.
russ_watters said:
Maintaining depth requires continuous control. It isn't a stable equilibrium. What idiot would build a sub with one depth gauge?
I'm still stuck on a lockout/tagout program for a gauge. :confused:
My father was the captain of the Ethan Allen, a nuclear sub, back in the late 60s. This is the sub that was blown up in the book of Hunt for Red October. While watching that movie with him, the underwater speed of the sub was mentioned, to which he replied "they go faster than that."
I asked him how fast they could go. He replied, "they go faster than that." He would not elaborate. This was in the mid 90s, talking, to his son, about a sub that was built in the 60s, and he would not tell me how fast it would go underwater.
I don't know how he ever found out that I had been working for the North Koreans since the early 70s (drafted when I was 7: "Find out how fast they go, and we'll make your brother stop hitting you!")
There was a discovery channel program about a rather 'eccentric' (ie mad) danish guy making home made submarines.
http://www.submarines.dk/ (unfortunately the spelling on his website is terrible)
Anyone know how a sub's reactor is cooled? I mean, if you've got steam turbines underwater, won't it leave a heat signature that can be detected?
An interesting boat. It launched the only armed nuclear missile full system test in US history. In 1962 it fired a fully armed Polaris missile. 12 minutes later, there was a 600 kT explosion.
  • · Replies 0 ·
