Ideal Gases dealing with scientific notation
The discussion focuses on using scientific notation to solve a problem involving gas volume changes due to temperature and pressure variations. The formula P1 x V1/T1 = P2 x V2/T2 is applied to determine the new volume of air needed in the house. A calculation error was noted, specifically the omission of the factor of 10^4 in the volume calculation. Mastery of scientific notation is emphasized as essential for success in science courses, with calculators providing tools to simplify these calculations. Understanding and correctly applying scientific notation is crucial for accurate problem-solving in gas law scenarios.
Janice
I am not sure how to properly use the scientific notation in this problem. I have attempted to solve it several different ways to no avail.
A house has a volume of 1.45 x 10(4)m(3). At 20.0° C and 740 mm Hg, the air fills the house. If the temperature and pressure increase to 35.0°C and 780 mm Hg, how much air must be drawn into the house to accommodate the change in volume of the air?
P1 x V(1)/T(1) = P(2) x V(2)/T(2))
V(2)= P(1) x V(1) x T(2)/ T(1) x P(2)
V(2) =740mm Hg x (1.45 x 10(4)m(3) x 308°K/ 293°K x 780mm Hg
V(2) = 330,484/228,540 = 1.44606 = 1.45
You also need to indicate the units of your answer.
Scientific notation is relatively simple to master: 1.45 * 10^4 m^3 = 1.45 * 10000 m^3 = 14500 m^3
Manipulating numbers expressed in scientific notation is the same as manipulating any number which is expressed as a product.
BTW: you have omitted the factor of 10^4 from your calculation of the volume of air drawn into the house.
If you plan on taking a lot of science courses, you must master scientific notation in order to perform calculations. Calculators have special keys to simplify entering numbers in scientific notation. Learn how to use them.
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
  • · Replies 16 ·
15K
