If c = A· E, then A - cE = 0.
  • Thread starter Thread starter press
The discussion centers on the equation A - cE = 0 and its implications in vector analysis, particularly regarding the component of vector A along the unit vector E. It is clarified that c represents the projection of A onto E, expressed as c = A·E. The participants explore the geometric interpretation of A - cE, noting that it is perpendicular to both E and cE, which leads to the conclusion that (A - cE)·E = 0. The conversation emphasizes the importance of understanding the relationships between these vectors and their geometric representation, particularly in the context of right-angled triangles formed by A, A - cE, and cE. Overall, the discussion aims to clarify the derivation and significance of the relationship between these vector components.
press
Let E be any unit vector, that is a vector of norm 1. Let c be the component
of A along E. We saw that c = A·E. Then A - cE is perpendicular to E, and A = A - cE + cE
Then A - cE is also perpendicular to cE ...
I just can't seem to figure where they got A - cE = 0 from. Everyone just shows A - cE = 0 is true on its own instead of showing if c = A·E, then A - cE = 0* which is what I think the author means by "We saw that c = A·E. Then A - cE is perpendicular to E".
Please, elaborate a little. Thanks.
edit: * if c = A·E, then A - cE · E = 0
Eh? Where does it say A - cE = 0? Are you trying to prove that A-cE is perpendicular to E?
Oh yeah, A - cE . E = 0
My bad.
You mean (A-cE)·E=0, I suppose. Geometrically, if E is a unit vector, then is cE not the vector component of A along E? So what is A-cE?
EDIT: heh, I wrote something silly, so I had to delete it
My book has the picture of this situation. Geometrically it's clear that A-cE is a vector perpendicular to E and cE.
A = A - cE + cE by parallelogram law. But why do we need A = A - cE + cE to see that A-cE is also perpendicular to cE when (A-cE)· E=0 implies (A-cE)· cE=0?
qspeechc said:
(A-cE)·E = (A-A·E·E)·E
Right? What is E·E when E is a unit vector?
E·E = 1.
Yeah, that second part I wrote is clearly rubbish, so I deleted it. The scalar product of three vectors is nonsense, because the product of two is a scalar.
A = A - cE + cE because -cE+cE=0. I think the point about A = A - cE + cE is that A = (A - cE) + cE, i.e. the vectors A, (A-cE) and cE form a right-angled triangle, with A as the hypotenuse. This is obvious geometrically, and I don't know what more is required.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
