If f(x-y). f(y)=f(x), f(5)=32, then what is f(7)?
The discussion revolves around a functional equation involving a function f, specifically the equation f(x-y)f(y) = f(x). Participants are tasked with determining the function f given that f(5) = 32 and are exploring the implications of this equation in the context of functional equations and exponential functions.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the nature of the functional equation and its relation to known forms, such as the Cauchy exponential equation. There are attempts to derive the function f based on given values and properties of exponential functions. Some participants question the uniqueness of the solution and explore different forms of f.
The discussion is active with various approaches being explored. Some participants have suggested that f could be of the form a^x, while others are analyzing the implications of the functional equation further. There is recognition that while certain values can be derived, the complete characterization of f remains uncertain without additional constraints or information.
Participants note that the functional equation allows for multiple forms of solutions, and there is a discussion about the continuity and differentiability of f. Some mention the need for additional conditions to uniquely determine f, such as continuity or differentiability at specific points.
littlemathquark
If f(x-y). f(y) =f(x), f(5) =32, then what is f(7)?
I can find f(0)=1 and f(1)=2 and f(7)=128.
I Wonder how can I find f function?
If you write ##z=x-y## then the condition becomes ##f(z)\cdot f(x)=f(z+x).## What do you know about this functional equation?
Yes, Cauchy exponansiyel equation, I mean ##f(x) =a^x##. But how can I find this?
You can use ##f(x)=a^x## with ##f(5)=a^5=32## and find ##a=2.## This is mainly by inspection.
We do not have enough information to uniquely determine ##f(x)##. All we know is that ##f(x)=a^{c\cdot x}## since these are all functions that satisfy the functional equation ##(*).## Hence, ## f(5)=32=2^5=\left(a^c\right)^5 \Longrightarrow 2=a^c## and all these functions are solutions. ##(a,c)=(2,1)## is only the easiest one.
Now, how do we know ##(*)##? Honestly, I am not sure. I would set ##f(x)=\sum_{k=0}^\infty a_k x^k## and try to figure out the coefficients ##a_k.## However, this requires that ##f(x)## can be written as a power series and I'm not sure whether this can be deduced only by the functional equation. I guess so, but I don't know the answer without trying.
Maybe just remembering the Exponential satisfies ##a ^{x+y}=a^x *a^y##.
@fresh_42 determined that ##f(x)=a^{cx}## and ##a^c=2##. Using the formula ##a^{cx}=(a^c)^x##, we have ##f(x)=2^x##. Or am I missing something?
I can find answer without finding f function:
##f(5)=f(4)f(1)=f(3)f(1)^2=\cdots=f(1)^5\implies f(1)=2##
##f(7)=f(6)f(1)=f(5)f(1)^2=32\cdot 2^2=128##
## f(1-1)f(1)=f(1) ##
## f(0)f(1)=f(1) ##
## f(0)=1 ##
By using
## \begin{align}
f(n x)&=f((n-1)x)f(x)=f((n-2))f^2(x)=f((n-3))f^3(x)=...\nonumber\\
&=f(1)f^{n-1}(x)=f(0)f^n(x)=f^n(x)\nonumber
\end{align} ##
and ## f(5)=32 ##
for ## x=1 ## it can be shown that ## f(n)=2^n ## with only whole numbers included into a domain of the function.
By using the next proof
## f(2x-x)f(x)=f(2x)=f(x)f(x) ##
## f(x-(-x))f(-x)=f(x)=f(2x)f(-x)\implies f(2x)=f(x)/f(-x) ##
## f(x)f(x)=f(x)/f(-x) ##
## f(x)f(-x)=1 ##
all integers can be included into the domain of the function.
The expression ##a^{cx}=(a^c)^x## is valid if ##a## is a positive real number and ##c## is ##c## any real number. The expression is not necessarily valid for negative values or complex values of ##a## or complex values of ##c##. However, this is a "Baby Rudin" level class. So it's probably a real analysis class, where the multiple vagaries regarding the complex exponential function simply don't come into play.
## f(0)f(1)=f(1) ##
## f(0)=1 ##
Note that one could also plug in ##x=y=0##, yielding ##f(0)^2 = f(0)##. There are two solutions, ##f(0)=0## and ##f(0)=1##. From ##f(0)f(x) = f(x)## and with ##f(0)=0##, one can deduce that ##f(x) \equiv 0\, \forall\, x##. You can however rule that other solution out due to the fact that ##f(5) = 32##.
You may need to add the requirement that ##f(x)## is continuous for all real ##x## to prove the already-found function is unique. Obviously, ##f(x) = 2^x## satisfies ##f(x-y)f(y) = f(x)## for all real ##x## and ##y##.
From f(x + y) = f(x)f(y) we know that f(nx) = f(x)^n for every positive integer n. That is sufficient to solve the question, but setting x = 1 we find f(n) = f(1)^n. Also for n \neq 0, <br /> f(1) = f(nn^{-1}) = f(n^{-1})^n \Rightarrow f(n^{-1}) = f(1)^{1/n} and for positive integer m we have f(n/m) = f(1)^{n/m}. so that f(x) = f(1)^x for positive rational x. Values for negative x then follow from f(|x|)f(-|x|) = f(|x| - |x|) = f(0) = 1.
It follows from the functional equation that <br /> \frac{f(x+h) - f(x)}{h} = f(x) \frac{f(h) - 1}{h} = f(x)\frac{f(h) - f(0)}{h} so that if f is differentiable at zero then it is differentiable everywhere, with f&#039;(x) = f(x)f&#039;(0).
Well, from the functional equation, it's a homeomorphism between an additive ring and a multiplicative one.
So if I integrate ##f'(x) =f(x) f'(0)## I can find f function. Thank you.
I know that if ##f## continuous one point, it's continuous everywhere. But ##f## is differentiable at zero why it is differentiable everywhere?
\begin{align*}
\lim_{h \to 0}\dfrac{f(a+h)-f(a)}{h}&=f(a)\lim_{h \to 0} \dfrac{f(h)-1}{h}\\
&=f(a)\lim_{h \to 0}\dfrac{f(0+h)-f(0)}{h}\\
&=f(a)\cdot f'(0)
\end{align*}
  • · Replies 19 ·
