If gradient of potential is zero, how is there a field?
In a circuit with resistors in series, the potential gradient is nearly zero at nodes, yet the same current flows through all parts of the circuit, including resistors. This raises the question of how current can remain constant despite a significant voltage drop across resistors, as current is proportional to electric field strength. The electric field can vary due to differences in resistivity, but the current must remain equal throughout the circuit to prevent charge buildup. Charge only accumulates when there is excess, and in a stable state, the same amount of charge crosses each part of the circuit simultaneously. Understanding these principles clarifies why electric fields and current behave as they do in circuits.
Electric to be
Consider a common circuit with some resistors in series. The nodes should have approximately the same potential. I know that truthfully the wire just has small resistance compared to resistors. However, even though the gradient of potential is approximately zero in a node, the same current flows through any node of a circuit as a resistor.
If the gradient of potential here is zero, and is non zero across a resistor, that would mean that the electric fields are different.
However, shouldn't the same amount of current be flowing across all parts of the circuit, and current is proportional to Electric field strength.Thank you.
As a side question, how does it come to be that the electric field is uniform everywhere in a circuit anyways? Is it because initially it isn't, and as a result of charge buildup throughout the circuit, the circuit compensates to become equal?
cnh1995 said:
Your thinking is on the right track.
https://www.physicsforums.com/posts/5310737/
Hope this discussion helps..
That somewhat helps with explaining why electric field remains constant (though I need to do some more looking into), but my main question is how can current be constant throughout a circuit with a resistor. If current is proportional to E, and therefore voltage, and if there is such a steep voltage drop over a resistor but little to none in the wire.
Actually, I guess the field doesn't have to be uniform, since the resistivity of a material can simply be larger. I guess my last question is why exactly does current have to be equal throughout? Is this simply to prevent charge buildup? And so what if charge did build up anyways?
Velocity of electrons is proportional to the electric field. It is like a water pipe with variable diameter. In larger diameter part, speed of water will be less than that in the smaller diameter part. But the "flow" rate (Volume/second) is constant everywhere. Can you extend this logic to resistors and wires?
Yes. Charge builds up only when it is "extra". Same current implies same charge crosses every part of the series circuit at the same time. Hence, there is no excess charge in any part. Surface charge build-up stops when this stable state is reached.
You can answer this question, using your calculator and putting in the values that are easy to find. The force between two charges q1 and q2, separated by distance x is given by
F= q1 q2/(4π ε0 x2) ( The Coulomb Force)
This will tell you the force you would need to 'squeeze' / build up two charges (say +1C each, corresponding to one Amp for one second, flowing in each direction down a wire and ' piling up' with a separation of say 1cm.
ε0 is the permittivity of free space - look it up and work out the answer. The value of the force should convince you why it can't happen. :wink:
Here, by build-up I mean formation of the surface charge rings. Excess charge ends up on the surface of the conductor.
  • · Replies 17 ·
