If light approaches a black hole will it accelerate?
The discussion centers around the behavior of light in the vicinity of a black hole, specifically whether light accelerates as it approaches a black hole. Participants explore the implications of light's mass, momentum, and the effects of gravity on light, drawing on concepts from both Newtonian gravity and General Relativity.
  • Some participants question whether light has mass, noting that while light has momentum, this seems inconsistent with the idea of massless photons.
  • Others clarify that photons are indeed massless, referencing the relationship between energy, momentum, and mass as described by the equation ##m^2 c^2=E^2/c^2-p^2##.
  • A participant expresses confusion about how gravity can affect light if it does not have mass, particularly in the context of black holes.
  • Some argue that Newtonian gravity is inadequate for explaining the effects of gravity on light, suggesting that General Relativity (GR) provides a more accurate framework by describing gravity as the curvature of spacetime.
  • One participant asserts that light does not accelerate and always travels at the speed of light (c) in a vacuum, although it can gain energy and be blueshifted when falling into a gravity well.
  • Another participant discusses the concept of light cones and how their orientation changes around a black hole, suggesting this may clarify the misunderstanding about light's behavior near a black hole.
  • There is a discussion about whether the deflection of light due to gravity constitutes acceleration, with some participants asserting that light always travels at c and follows a geodesic in spacetime.
  • Some participants challenge the application of Newtonian concepts to massless objects, questioning how gravitational force applies to light.
  • A recent thread on the same topic is referenced for additional context.
Participants express a range of views on the nature of light and its interaction with gravity, with no consensus reached on whether light accelerates in the context of approaching a black hole. The discussion remains unresolved regarding the implications of mass and momentum in relation to light's behavior in gravitational fields.
Participants highlight limitations in applying Newtonian gravity to light, noting that the behavior of light in strong gravitational fields is better described by General Relativity. There are unresolved questions regarding the definitions of acceleration and the implications of masslessness.
hayden47
If light approaches a black hole will it accelerate? I think this question ties in with whether light has mass or not. Does light have mass? It seems accepted that light has momentum, but this is not consistent with saying that photons are mass-less (momentum=mass*volume). Could someone clear this up or is it actually a contradiction? Mass is a requirement for gravity also. I've always heard that not even light can escape a black hole which is gravitational force, so wouldn't a black hole have enough force to accelerate light?
Photons are massless. The relationship between energy, momentum, and mass is ##m^2 c^2=E^2/c^2-p^2##. For photons ##p=E/c## so the mass is 0 despite having both energy and momentum.
Oh I see. I'm still confused then of how gravity can affect light if it does not have mass (such as a black holes' effect on light).
Why should that matter?
First, Newtonian gravity is experimentally known to be wrong wrt the effect of gravity on light.
Second, in GR gravity curves spacetime and spacetime clearly affects light.
Third, even if you ignore the previous two points it takes 0 force to accelerate something without mass, so the fact that the Newtonian force is 0 doesn't imply that the acceleration is 0.
Second, in GR gravity curves spacetime and spacetime clearly affects light./QUOTE]The whole idea of Newtonian gravity is that gravity is the force that causes the attraction of masses and is caused by mass. Of course this would not work with light if it is massless. So perhaps it is accidentally correct when dealing with two masses.
GR gravity IS the curve of spacetime right? So if that is what is affecting the light and everything else, then I'm asking will a bend in spacetime as great as a black hole cause light accelerate?Sent from my iPhone using Physics Forums
Light does not accelerate. It always moves at c in a vacuum. It will, however, gain energy by falling into the gravity well and be blueshifted.
If you are imagining that the light that can't escape the BH is traveling away from the BH and being slowed down or stopped by the BH's gravitational acceleration... and therefore supposing that the reverse would be that the BH can accelerate light moving close or toward the BH, then maybe this line of thinking may be causing the problem.
Look for something about light cones, and how they change "orientation" around a BH.
Here is an example - http://www.phy.syr.edu/courses/modules/LIGHTCONE/schwarzschild.html
The light that can't escape the BH does not have a radial direction component away from the BH in its future light cone... the light cones can be oriented so that their "outer" edge is tangent to the event horizon.
(I've probably butched this description, but I think it is the concept needed here).
Acceleration is a change in velocity. Velocity is a measurement of direction and speed. The website you pointed me to says "The Einstein Theory correctly predicted the amount of the deflection of starlight". Is this acceleration?
No. As Drakkith said, light always travels at exactly c in a vacuum. It also always travels in a "straight line", BUT ... a "straight line" in a high gravity field is a "straight line in spacetime" and that is not quite what you normally mean by "straight line". The deflected path IS a "straight line in spacetime", which in more formal parlance is called a "geodesic".
And how much force does it take to accelerate a massless object. What does Newtons 2nd law say?
Sure it would. Plug 0 in for the mass, what is the gravitational force? How does that compare to your answer above?
Newtonian gravity gives the wrong behavior for light, but not because of it being massless.
  • · Replies 20 ·
  • · Replies 62 ·
10K
  • · Replies 51 ·
  • · Replies 22 ·
  • · Replies 40 ·
