Why doesn't gravity speed up light?
The discussion centers around the question of whether gravity affects the speed of light, particularly in the context of general relativity and various phenomena such as the Shapiro delay and gravitational lensing. Participants explore the implications of light's behavior in gravitational fields, including how it is perceived by different observers and the nature of light's interaction with gravity.
  • Some participants argue that gravity speeds up objects with mass, like meteors, but question whether light, which has no mass, behaves similarly when aimed at a massive body.
  • Others assert that light does not experience acceleration due to gravity because it has no mass, although they acknowledge that light can be affected by gravity through its energy.
  • It is noted that to a local free-falling observer, light always travels at the speed of light (c), while to a distant observer, light may appear to be delayed or slowed down when passing through a gravitational field.
  • Some participants mention the Shapiro delay as a phenomenon that illustrates how light takes longer to traverse regions of space influenced by gravity compared to a vacuum.
  • There is a discussion about gravitational lensing and the deflection of light, which some participants cite as evidence that gravity does affect light despite its lack of mass.
  • One participant raises the question of whether the Shapiro delay is what prevents light from speeding up further in a gravitational field.
  • Some contributions emphasize that while the speed of light remains constant in local inertial frames, distant observers may perceive light traveling at different effective speeds due to gravitational effects.
Participants express differing views on the effects of gravity on light, with some asserting that gravity does not affect light due to its lack of mass, while others argue that light is influenced by gravity through its energy and the curvature of spacetime. The discussion remains unresolved with multiple competing perspectives.
Participants note that understanding the effects of gravity on light requires consideration of general relativity and the nature of spacetime, which complicates the discussion. There are references to specific phenomena like the Shapiro delay and gravitational lensing, but the nuances of these concepts are not fully explored in the discussion.
Yashbhatt
We know that gravity speeds up a body, like a meteor which enters the Earth gets constantly speeded up by Earth's gravity.
And from relativity we know that light bends near a massive body because Newton's law of gravitation is just an approximation and actually gravity depends on energy and momentum.
So my question is: If a ray of light is aimed exactly at the centre of a body, then will it get accelerated like a meteor? And if does get accelerated, then won't it surpass the universal speed limit of 3,00,000 km/s (approx.)?
Science news on Phys.org
Gravity does not effect light because light does not have mass.
- To the local free falling observer it will always move at c.
- To a distant observer it will appear to be slowed down. Light needs more time to pass a region containing mass/energy, than a region of vacuum with the same outer dimensions.
Well, I'm not sure that's quite right. A BODY moving in a gravitational field appears to a remote observer to move slower but the light from that body hitting the eye of a remote observer will be traveling at c, it's just that it will be red-shifted.
I expect that A.T. is talking about the Shapiro delay.
No, a massive body fired radially at a mass with v<<c will be accelerated, so it will move faster than without the mass. So it needs less time to pass a region containing mass/energy, than a region of vacuum with the same outer dimensions.
Locally every free falling frame has light traveling at c. That doesn't change the fact that light needs more time to pass a region containing mass/energy, than a region of vacuum with the same outer dimensions.
Nugatory said:
I expect that that A.T. is talking about the Shapiro delay.
Interesting. I didn't even know about that. Thanks.
That is wrong, and numerous experiments showed a clear effect.
Light has energy, that is sufficient to interact via gravity.
And for v~c, there should be a speed where the non-relativistic effect (increased speed) and the relativistic effect (Shapiro delay) have the same size, so the total effect is zero.
Yes as mfb said, that's wrong
gravitational lensing of light is proof :smile:
cheers
Dave
And the deflection of starlight by the sun, the Shapiro delay and gravitational redshift of light emitted from massive objects like stars and black hole accretion disks.
Modern atomic clocks are so precise, gravitational redshift from Earth can be measured with GPS satellites and even within a few meters of height difference in labs.
What is Shapiro delay?
And someone said that it would appear to move slower for a distant observer but that's not true. The value of c is same for all reference frames.
http://en.wikipedia.org/wiki/Shapiro_delay
Light speed propagates at c in inertial frames of reference, which exist only locally in curved space time. Distant observers can observe light to propagate at other speeds than c.
But is Shapiro delay the thing which prevents light from speeding up further?
There have been no replies for a while.
iirc: You are in High School.
The High-School level explanation is that it is a property of the Universe that all observers will measure the same speed for light in a vacuum. This is why gravity does not speed light up. As a reason it amounts to "just because" but that's the nature of science: some things just are. Finding those things that "just are" is one of the deeper aims of physics.
OTOH:
- because the speed of light is always the same, gravity can make the light change color ;)
- because the speed is always the same, gravity is understood in terms of curving space (+time).
Light is affected by gravity because gravity curves space (+time) - in zero gravity, light travels in straight lines but in gravity light travels in curves.
The Shapiro delay is, loosely, showing you that it takes longer to go in a curve than in a straight line.
The advanced folk are probably having fits over this description - I've left a LOT out so be careful not to draw general conclusions from this. It is quite difficult to do this physics justice at HS level.
Thanks Simon. You always prove helpful.
The OP asked about light traveling radially, in a straight line. There is no light bending here, but there still is a delay compared to empty space.
There is light bending in 4-dimensional spacetime.
It is pointless to try to understand GR in 3-dimensional space. It just does not work.
Of course, so it is probably worth reiterating that the bending happens in "space (+time)" and that I've "left a LOT out" of the high school level description.
That's all in post #15 but may not be clear enough.
I agree with mfb.
This is where people usually get caught out from staring too hard at rubber sheets.
  • · Replies 51 ·
