If they are real, what exactly do gravitons do?
  • Level: Graduate
  • Thread starter kashiark
    Gravitons
62 replies · 17K views · last reply
apeiron said:
Isn't the answer simply that the Earth also radiates the "light" of gravitons in this model? So the Earth blocks the sun, but there is no shadow as the Earth then itself glows brightly to the other side. The degree to which it shields would be equalled by the degree to which it attracts.
Actually, are you saying that the Earth absorbs gravitons, and then re-emits those same ones? That might work actually. Maybe. I dont's know for sure.
Even do, if the gravitons are re-emitted, then they would be re-emitted sporadically. A graviton would have to penetrate through or travel through a lot of material to get to the other side, wouldn't it? I still don't get why it wouldn't be shot back in the direction it came from. And if it did shoot in a different direction, again, it wouldn't bend around the Earth unless it couples with other gravitons from the earth, which I adressed in the last post. So either it couples with other gravitons, or it penetrates through the Earth in order to reach the other side.
benk99nenm312 said:
Either gravitons don't exist, or they are able to interact with themselves. Does anyone know if gravitons couple with other gravitons? That's something I'd be interested in finding out. I dson't believe they do, but I could be wrong.
I typed up an essay for the annual gravity essay contest that addresses the question of how gravitons interact with gravitons. The essay got an "honorable mention" and was invited for review and publishing in IJMPD. The essay, as submitted to IJMPD is here:
http://www.brannenworks.com/gravity2009.pdf
The whole idea of gravity as created by gravitons is why I want to see the Feynman paper on the subject.
I was being tongue-in-cheek, giving a classical way out of the classical way you are imagining the situation.
I'm not expert in this area but I believe that a more correct approach would see it as a field story, knit together by virual rather than actual gravitons. So if you have your stretchy trampoline, the sun would make such a big dent that the Earth would already be halfway down a gravity well. Object to the other side of the earth, like a satellite, would be already sliding down due to the dent caused by the sun, and the Earth would then make a dent upon the dent.
Gravitons would only appear as actual particles as the result of a sufficiently excited field. So you would need a rapidly wobbling mass to make waves/particles as observables?
Perhaps this is the black hole story as well? Only virtual gravitons being virtually emitted. And you would need to waggle the black hole about to shake out actual gravitons from the event horizon?
Exactly! I was trying to say that for ten posts or so, but I'm so bad with words that it never came out right. :smile: Nicely put. And yes, this is what I am worried about. I don't know how one would solve the problem with gravitons.
Buckethead, I don't think velocity causes dilation. The acceleration getting to the velocity is what causes the time dilation.
This is very interesting. Nice job. I lack some of the math to understand parts of this but I get the just of it. So, is it a consencus that gravitons interact with others or is it still debated?
No, they're unobserved, there is just a graviton shaped hole in current quantum theories which suggests we should find one.
benk99nenm312, let me try again. Your view of what a graviton is has nothing to do with what physicists mean when they say the word "graviton".
I can have a static electric field, and charged objects feel a force in that field. I can also have excitations in that field, and they are called photons. That doesn't mean that charged objects must emit photons - a charged object doesn't have to glow.
I can have a static gravitational field, and massive objects feel a force in that field. I can also have excitations in that field, and they are called gravitons. That doesn't mean that massive objects must emit gravitons for exactly the same reason a charged object doesn't have to glow.
Your complaints about gravitons are based on a model that has nothing to do with what physicists mean when they say the word "graviton".
But if the charged object in the field wants to interact with another charged object, it mediates photons between them, right?
No. That would mean it glows.
You might have heard virtual photons are exchanged. Virtual photons are not real photons. You can't see them; you can't measure them; you can't count them; you can't detect them. You don't even need them to do the calculation. They are mathematical artifacts - on par with drawing an auxiliary line in geometry.
So you are saying that gravitons are mathematical artifacts?
A photon is real when it is not mediating the electromagnetic force. When is a graviton real?
That is exactly my question: what are gravitons? physical particles? virtual obejcts derived from perturbation theory (which in inconsistent for GR)? a mathematical concept in Hilbert space? ...
My feeling is that the failure of naive perturbation theory for GR forces us to think about different concepts. If you look at some recent approaches for quantum gravity (loops, dynamical triangulations) you wan't find anything like a graviton in the fundamental concepts. That does not mean that these theories are wrong, it simply means that the concept of ordinary quantum field theory cannot be applied to quantum gravity.
That is well known, I thought. If it did work perfectly, we'd have a very good candidate for a unified field theory.
As for LQG, the actual links between nodes in spin foam models could be described as gravitons at least metaphorically.
Trying to fit things to actual physical particles isn't a helpful idea though, you can speak sensibly of wave-like or particle-like behavior, but assuming there is a neat little transverse wave diagram or point like particle down in there is misleading at best.
We know that whatever this stuff is, it behaves in certain ways which we can often find easily understandable metaphors for in our day to day experience.
We still aren't sure what this stuff actually IS exactly though.
Applying the methods which have successfully produced the Standard Model to Gravity is very difficult, but a few things happen when you do.
When you include the SSB/Higgs Mechanism, you get a Spin 0 Massive Boson shaped "hole" in the theory, and Spin 2 Massless Boson shaped "holes". The relationship between other symmetry groups and their bosons suggests the Spin 0 one should be the Higgs, which should then couple to other particles in certain ways to produce their observed masses.
The nature of Gravity in that it has no "poles" plus seems to propagate at light speed suggests the Spin 2 one should be a Graviton. This is at odds with the smooth continuum of spacetime described by GR, and one of the big problems seeking resolution which drives String/LQC/etc Theories.
Max!
I fully agree with you - but reading the other posts I don't think that the colleagues have the same opinion.
I think that the graviton in LQG (if this concept makes sense at all) is the fundamental excitation of a spin network.
But the majority seems to have something in mind that is derived from ordinary quantum field theory, something like quantized plane waves. This is INCONSISTENT in GR. A plane wave in LQG is a very complex spin network state. I do not understand Rovelli's arxiv papers completely, but I understand enough to see that it is not the "ordinary graviton" as the majority may expect.
The problem with ST is that it works fairly well perturbatively (and therefore ST is able to tell us what the perturbative graviton is), but I do not see results for fully dynamical spacetimes with propagating gravitational fields (not necessarily plane waves).
Tom
No, I am saying that virtual gravitons are mathematical artifacts. Just like virtual photons.
Just like when the photon is.
I don't understand. If the graviton were real at any given time, what would it do? What would be its effects? What would we measure, detect, observe? Why haven't we observed it then?
Are you falling towards the center of the Earth currently?
There's your answer, I think.
So are you saying that, when real, gravitons have no effect what-so-ever on me or anything else.
This would indicate to me that they are not 'real'.. ever. That's why I'm confused.
(The only way something has absolutely no effect on anything else is if it doesn't exist.)
Again, it's a very misleading way to think of things.
Mathematically it is convenient to describe electromagnetic fields in terms of particles shooting photons at each other, and it turns out that light, real photons, actually has electromagnetic properties.
The difference being you don't see magnets "glowing" at each other literally.
So right now your butt is "glowing" at the Earth with virtual gravitons in a convenient mathematical description.
So a gravity wave (literally a ripple in spacetime) would be akin to a photon in that it would be a defined waveform with gravitational properties instead of electromagnetic properties.
There's more truth and understanding to be found in that comparison if you really consider the nature of a magnetic field and light.
Yes, now I see. This helps define a graviton. Now the OP's question is somewhat answered. So is some of mine. Thanks.
So here's my question. If a satelite is positioned behind earth, as before, then how does a virtual graviton emitted from the sun interact with the satelite? Is the answer simply that it does not exist? That it is a mathematical artifact, and therefore is useless to apply in real nature (which is by the way, what we do, right?)? We try to answer what is happening in nature, so a mathematical description is great, but if a virtual graviton is not a viable conceptual explanation, GR seems much more appropriate. So again what I guess I really want answered is, how does a graviton reach a satelite behind earth?
Isn't there an equivalent question now in how does the sun's magnetic field reach through the Earth to affect the satellite.
So in everyday physics, what is the effect of an insulator placed in the path of a magnetic field?
benk99nenm312 said:
but some also are dragged by gravity and bend aound the earth...
Photons can still bend around earth, because they are now interacting with gravitons, but gravitons can't do that now (unless they somehow interact with themselves).
:smile: Is it possible that "gravitons can create gravitons"? Since Graviton is something therefore it has energy. All energy can curve space-time. Therefore gravitons can create gravitons?
This is much like in Q.C.D where Gluons can make Gluons(called "Gluon Ball"?). Maybe this property can unify gravity and the strong force?
By this wouldn't gravitons be able to bend around earth? Since it would create a gluey, stretchy and bendy property so it would cover Earth and everywhere.
"All energy can curve space-time" according to relativity. Does relativity still hold after one throws out the notion of a graviton? That is the key. To me, that's like using gravity to explain gravity. If gravitons do curve space-time, someone please let me know, because then, everything will make sense.
Max™ said:
What would it take to insulate something from gravity?
Well that's my point. in reality, I don't know of anything that can. I mean, when electric force repels, it over-powers and counters gravity, but nothing just simply sitting in the way, like the earth, is going to counter gravity.
I think I already gave answer to this a few posts back.
That was my point. Doesn't the same issue apply to virtual force particles of both kinds of field?
So citing wiki: even a Faraday cage will not shield its contents from static magnetic fields
http://en.wikipedia.org/wiki/Faraday_cage
Now I might be piecing this together. I thought that the Earth being in the way would dicipate the electromagnetic force, because less photons are recieved. And the only reason some are received is because they are bent around the Earth due to gravity. But the electromagnetic force runs on virtual photons. They are evidently so unreal that they can jump right through the earth, I think. I don't know for sure, or how. But the electromagnetic force must be able to get to the other side somehow.
So, now I ask, is the electromagnetic force dicipated by the Earth's presence? If so, I still don't have an answer to what's bothering me. If not, then we're good.
Are you saying that you can not detect all of virtual particles? What about Casimir effect?
