I'm stuck with a differential equation
The discussion centers on solving a specific fourth-order differential equation of the form ((Ax+B)^4)y'''' + ((Ax+B)^2)y'' + (i/const.)y = 0, where A, B, and const are constants, and i represents the imaginary unit. The solution involves changing the variable to x = (tA-B)/A, transforming the equation into an Euler-type equation. The general solution is expressed as y(t) = C1t^z1 + C2t^z2 + C3t^z3 + C4t^z4, with z values derived from an algebraic equation. The discussion also touches on the treatment of i/const. as a constant in the context of physical problems.
  • Understanding of ordinary differential equations (ODEs)
  • Familiarity with Euler-type equations
  • Knowledge of complex numbers and their applications in differential equations
  • Experience with variable substitution techniques in ODEs
  • Study the properties and solutions of Euler-type equations
  • Learn about variable substitution methods in differential equations
  • Explore the implications of complex coefficients in ODEs
  • Review literature on physical applications of differential equations, particularly in wave mechanics
Mathematicians, physicists, and engineering students dealing with differential equations, particularly those interested in complex analysis and wave phenomena.
vinodjoshi
Please Help ...... Urgent
Hello ppl
I stuck with a differential equation and all I need is your kind help. While solving a problem I got one eqaution as given below
((Ax+B)^4)y''''+ ((Ax+B)^2)y''+(i/const.)y=0
i denotes complex no (iota).
I need your kind help. Please suggest me the possible way to solve this equation.
Thanks in advance
First, change variable
x = (tA-B)/A,
where t is new variable. Your ODE in new variable is
(At)^4y''''+ (At)^2y''+(i/const.)y=0 (2)
this is an "equipotential" equation, also known as an "Euler-type equation".
Then seek solution in form y(t)=t^z. Substitution y(t)=t^z to (2) leads to
t^z(A^4 z^4-6 A^4 z^3+11 A^4 z^2-6 A^4 z+A^2 z^2-A^2 z+(i/const.))=0,
There are four solutuons of algebraic equation (z1,z2,z3,z4)
A^4 z^4-6 A^4 z^3+11 A^4 z^2-6 A^4 z+A^2 z^2-A^2 z+(i/const.)=0,
so the general solution of ode (2) is as follows
y(t)=C1t^z1+...+C4t^z4
where C1...C4 are arbitrary constants.
Thanks kosovtsov for your kind help.
Sir can you briefly explain about these "Euler Type Equations". Can you give me some references for these equations.
Sir
Can we treat i/const. as a constant. I am confused about it. Please help me in this regard. Can you suggest me some book having similar kind of problem. I will be thankful to you.
Yes, I have considered i/const as a constant. But real meaning of it belong exclusively to the physical problem setting. I know nothing on the physical base of your problem.
Sir, The physical problem belongs to planer wave where the physical medium which carries this wave have tapered cross section. Can this thing help you or I have to explain the problem in detail. All I want to ask (i/const.) is a complex no. so how can we take it as real no.
