Can the Double Slit Experiment Reveal Information About Parallel Dimensions?
The forum discussion centers on the implications of the double slit experiment in relation to parallel dimensions. The original poster theorizes that by manipulating the spacing of the slits in the experiment, one could potentially observe differences in interference patterns that may indicate interactions with electrons from a parallel dimension. However, the consensus is that any observable differences are unlikely, as the electrons are actually interfering with their own wavefunctions rather than with 'other' electrons. The discussion concludes that the results of such experiments are likely inconclusive regarding the existence of parallel dimensions.
  • Understanding of quantum mechanics principles, particularly wave-particle duality.
  • Familiarity with the double slit experiment and its implications for quantum interference.
  • Knowledge of wavefunction behavior in quantum physics.
  • Basic grasp of dimensional theory in physics.
  • Explore the implications of wavefunction collapse in quantum mechanics.
  • Research the concept of parallel dimensions in theoretical physics.
  • Investigate advanced quantum experiments that test the limits of wave-particle duality.
  • Learn about quantum entanglement and its relation to multiple dimensions.
Physicists, quantum mechanics enthusiasts, and anyone interested in the theoretical exploration of parallel dimensions and the double slit experiment.
Martyn Adams
Assuming that the double slit experiment creates interference patterns when electrons interact with themselves (or 'other' selves) from a parallel 'space' - one wonders if one can 'image', or at least gain more information about that other 'space' (dare I use the word 'dimension'?) in which the 'other' electrons originated.
I know there's lots of assumptions here - but stay with me...
If we increase/decrease the spacing of the gaps in the double slit experiment slowly (within tolerances), one would expect the experiment to continue to work with the interference pattern changing in time to match the changes in the spacing.
However if we make the changes at, say, a TV signal frequency would the the changes keep up exactly, or would there be a slight difference? If we vary the spacing with a live TV signal of the experimenter, the electrons would still form an interference pattern, varying at the same TV signal frequency. Any discrepancies between the expected interference pattern and the actual received interference pattern would be the difference between the TV signal from here to the one generated (or 'experienced' by the 'other' electrons).
I know there are many naive assumptions here - but what if the 'other' electrons (those with which 'our' electrons interfere with) come from a close parallel dimension? If there are any viewable differences - we should be able to detect them. Maybe the experimenter in the other dimension as a beard? If that's so we should be able to see it.
If we get no differences between the expected and actual received interference patterns this may be because the 'other' electrons originate from this 'dimension' (i.e. there's no 'dimensionality' element at all or maybe close dimensions collapse back to each other) or that the other 'dimension' is so close to ours as to make no detectable difference. I.e. The result is inconclusive. I fear this is the most likely result.
Other possibilities include interactions with many other 'dimensions' simultaneously, which may degrade the generated TV image - perhaps to an unrecognisable signal of pink noise.
Nevertheless any other results would be interesting in their own right.
Thanks for the post! Sorry you aren't generating responses at the moment. Do you have any further information, come to any new conclusions or is it possible to reword the post?
No, there is no known way to communicate with or detect a parallel dimension.
The electrons are interfering with themselves. (More accurately, their wavefunctions.) There are no 'other' electrons.
Since the OP's question has been answered and discussion of parallel universe is not allowed, I'm going to lock this thread.
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
14K
  • · Replies 20 ·
21K
  • · Replies 32 ·
  • · Replies 21 ·
  • · Replies 60 ·
