Impact Force on a Spring or Damper
The discussion focuses on calculating impact force on a hard rubber component using a dynamic test rig. The user seeks to replicate a previous test involving a 78 kg mass dropped from a height, now requiring a method to determine the peak loading based on displacement. Key equations mentioned include the spring force equation F = kx and the kinetic energy equation KE = 0.5mV², which relate to the energy absorption during impact. The conversation emphasizes the need to consider the elastomer's spring rate, which may vary under compression.
  • Understanding of basic physics principles, specifically kinetic energy and potential energy.
  • Familiarity with the spring force equation (F = kx).
  • Knowledge of elastomer properties and behavior under stress.
  • Experience with dynamic testing equipment and setup.
  • Research methods for calculating impact force on elastomers.
  • Learn about dynamic testing rig configurations for shock impact simulations.
  • Investigate techniques for measuring the spring rate of elastomers.
  • Explore advanced dynamics concepts such as energy absorption in materials.
Engineers, materials scientists, and technicians involved in testing and analyzing the performance of elastomers and dynamic systems.
Nick C
Hello Everyone, I'm hoping you can help with this.
I need to set up a test on a dynamic test rig which can simulate shock impacts upon a spring (actually it's a hard rubber based component).
The test has previously been done on a rig which dropped a mass of 78Kg onto the part until destruction, but the equipment is no longer availble. Therefore I want to find a solution which allows me to use the dynamic rig which can provide shock impacts which are controlled by displacement in mm.
So, my question relates to how I can calculate the impact force upon the part when I know the following:
1) Mass of the object being dropped
2) Height of the object being dropped
3) The density of the part being hit, in N / mm (The rubber part)
I can then set the equipment to cycle over a displacement which provides the correct peak loading from the calculation.
I hope I have provided enough info.
Thanks in advance!
Nick
Do you mean maximum force? Consider a spring for example. The force on the spring when something impacts it increases until all the kinetic energy of the impacting object has been absorbed by increasing the potential energy in the spring. So the force on the spring varies depending on displacement according to the spring equation:
F = kx
The maximum force is when the spring is fully compressed and has thus absorbed all the energy of impact.
KE object = E spring
.5mV^2 = .5kx^2
Solve for x (spring displacement) then find the force on the spring. Note that this neglects any potential energy from the mass as it compresses the spring which may or may not be significant. That's easy enough to add into the equation and from the sounds of your set up, it may be necessary. You'll need to describe the set up better though.
The same holds true for any elastomer. The elastomer has some spring rate which may or may not change as the elastomer is compressed. There's no easy way I know of to calculate an elastomer's spring value from it's geometry and properties. You may need to measure it.
  • · Replies 16 ·
  • · Replies 31 ·
