Mass-spring-damper problem for kayaking waterfalls
  • Thread starter WW Kayaker
    Mass Spring
31 replies · 5K views · last reply
WW Kayaker said:
Sorry, for some reason my email stopped sending notifications of replies to this thread so I just now saw the most recent comments.
The PF email notification let's you know only when the first post appears after your last view of the thread. PF knows when you view PF, but not when you view the email.
So if you get the email and view the enclosed summary, but do not visit PF and view the thread, then PF sends no more notifications for that thread.
Always check that the posts have not extended to another page.
WW Kayaker said:
However, I suspect the water doesn't act like a spring but more like a damper with uniform rate of dampening during the entire impact.
OK, let's model the water as a pure damper, that is ##F= -Cv## where ##C## is a damping coefficient.
We already know the initial velocity upon impact, i.e. ##v_0 = \sqrt{2gh}##. Knowing that ##v = \frac{dx}{dt}## and ##F = m\frac{dv}{dt}##, then:
$$F = mv\frac{dv}{dx}$$
$$-Cv = mv\frac{dv}{dx}$$
$$dx = -\frac{m}{C}dv$$
$$\int_0^d dx = -\frac{m}{C}\int_{v_0}^0 dv$$
$$d = \frac{m}{C}v_0$$
Thus we can estimate ##C## if we know the distance ##d## that the kayak sinks in:
$$C = \frac{mv_0}{d}$$
The maximum damping force will be at maximum velocity, which is at ##v_0##:
$$F_{d\ max} = C v_0 = \frac{m}{d}v_0^2 = \frac{2mgh}{d} = \frac{2Wh}{d}$$
For ##W= 175\ lb##, ##h = 20\ ft## and ##d= 6\ in##, then ##F_{d\ max} = 14\ 000\ lb##.
What difference will adding a spring in series do? Assuming the ideal case where the spring compresses completely before the kayak begins sinking:
$$v_0 = \sqrt{2gh - \frac{K_s}{m}x_s^2}$$
and
$$F_{s\ max}= K_s x_s$$
$$F_{d\ max} = \frac{m\sqrt{2gh}}{d}\sqrt{2gh - \frac{K_s}{m}x_s^2}$$
The spring constant necessary to achieve a compression of ##2"## without bottoming out is ##5930\ lb## which will give ##F_{s\ max} = F_{d\ max} = 11\ 860\ lb ##, same as with the 2 springs in series. With any other spring constant, either ##F_{s\ max}## or ##F_{d\ max}## will increase (up to ##14\ 000\ lb##).
I thought that was an interesting result. I guess it means that there is a maximum value for the energy that you can absorb with a spring under the seat, no matter how the energy will be dissipated afterward.
