Implicit differentiation problem
The problem involves implicit differentiation of the equation ##x\sqrt{1+y} + y\sqrt{1+x} = 0##, with the goal of proving that ##\frac{dy}{dx} = \frac{-1}{(x-1)^2}##. The discussion centers around the application of implicit differentiation and the use of partial derivatives.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the use of implicit differentiation versus partial derivatives, with some suggesting that the original equation could be manipulated to eliminate the ##y## variable. Others question the necessity of partial derivatives in this context.
There is an ongoing exploration of different methods to approach the problem, including suggestions to square both sides of the equation or to differentiate directly. Some participants express uncertainty about the implications of certain manipulations and the conditions under which the original equation holds.
Participants note the importance of ensuring that the expressions under the square roots remain non-negative, leading to discussions about the conditions on ##x## and ##y##. There is also mention of potential mistakes in the original problem statement and the implications of those errors on the solution process.
IonizingJai
If ##x\sqrt{1+y} + y\sqrt{1+x } = 0##, then prove that ##\frac {dy} {dx} = \frac {-1}{(x-1)^2}##.
2.Relevant Equations:
$$ \frac {dy} {dx} =
- \frac {\left (\frac {\partial f}{\partial x} \right)} {\left( \frac {\partial f} {\partial y} \right)}.$$
3. The Attempt at a Solution :
Given expression : ##x\sqrt{1+y} + y\sqrt{1+x } = 0##, let's call it ##f(x)##.
Now, finding partial derivatives of ##f(x)## w.r.t x and y.
$$\frac {\partial f} {\partial x} = \sqrt{1+y} + \frac y {2\sqrt{1+x}}.$$
$$\frac {\partial f} {\partial y} = \frac x {2\sqrt{1+y}} + \sqrt{1+x}.$$
Now,
$$= - \frac {\left( \frac { 2\sqrt{1+x}\sqrt{1+y}~+y }{ 2\sqrt{1+x} } \right) } {\left( \frac { 2\sqrt{1+x}\sqrt{1+y}+~x }{ 2\sqrt{1+y} } \right)}$$
I'm stuck here. Since I don't know what should I do to get to the required result.
You have not used the given fact that ##f(x,y)=0## so far. I am sure there is some clever substitution that will allow you to eliminate the ##y## variable.
Your thread title says that this is an implicit differentiation problem. Why don't you do it that way?
Just take the derivative with respect to x of each term on the left side of your equation. There is no need for partial derivatives, as the assumption in implicit differentiation is that, in this case, y is a differentiable function of x.
Also, this is a purely math problem, so I am moving it to the calculus section.
Now,
Are you sure that this is true ?
IonizingJai said:
dydx=−(∂f∂x)(∂f∂y)
dy/dx tells us to derive the function y=f(x) with respect to x.
Yes, the equation as stated in post #1 is correct.
If ##f(x, y) = 0##, the the total differentials of both sides have to be equal.
##\frac{\partial f}{\partial x}dx + \frac{\partial f}{\partial y}dy = d(0) = 0##
##\Rightarrow \frac{\partial f}{\partial y}dy = -\frac{\partial f}{\partial x}dx##
##\Rightarrow \frac{dy}{dx} = -\frac{\frac{\partial f}{\partial x}}{\frac{\partial f}{\partial y}}##
IMO, though, partials are overkill in this problem, but using ordinary implicit differentiation still ends up with a messy answer that doesn't look like what is supposed to be proved.
You can move one radical in the given expression to the other side, square, solve the quadratic for ##y## and throw out the solution that does not satisfy the given expression. Then just take the derivative of the good solution as @Mark44 suggested. I don't agree that it's messy, but I agree that you don't get the answer that you are asked to show.
That's pretty much what I meant by calling it "messy."
I would do what kuruman suggests only if I had to. As you are invited to get rid of y, and as what causes most of he trouble in this sort of calculation are √ terms, I would start by applying your first equation in 1.
not even to your equation for dy/dx but better to
to get rid of √(1 +y) and see where that leads you.
Or another idea. Get rid of square root terms in the original equation 1 and then do the implicit differentiation.
Thanks to all who replied.
Here's what I did, as kuruman suggested,
First, covert given expression to
$$\frac {x} {y} = -\frac{\sqrt{1+x}}{\sqrt{1+y}} $$
Then, squaring b/s we get, ##\frac {x^2} {y^2} = -\frac{1+x}{1+y}##, manupulating expression to get , ## x+ y +xy = 0##.
$$ y = -\frac{x}{1+x}$$ .
Applying condition ##\frac{1-x}{1-y} \gt 0## we get ##x\gt -1##.
(I have further doubt here, wherther to apply condition for ##\frac {x} {y} = -\frac{\sqrt{1+x}}{\sqrt{1+y}} ## or substitute for y in x in the given expression ##
## in order to throw out the intervals in which the parent equation becomes invalid. )
Anyway, we diffrentiate the equation ## y = -\frac{x}{1+x}## to get ##\frac{dy}{dx}## and the result as required.
##\frac{dy}{dx} = -\frac{1}{(1+x)^2}##, and the problem said
prove that ##
Sorry, I made the mistake in OP and it went unnoticed even after I gave it a check, I find writing LaTeX code difficult, apologies for any time waste, my mistake might have caused.
I will edit the OP, okay?
Looks like there is no option to edit the post.
so, I will post it here:
EDIT : the required result was ##\frac{dy}{dx} = -\frac{1}{(1+x)^2}##.
All is clear now :smile:
If you square ## -\frac{\sqrt{1+x}}{\sqrt{1+y}}##, you get ##\frac{1+x}{1+y}##, not ##-\frac{1+x}{1+y}##.
x>-1 and y-1 should hold otherwise you get zero or negative number under the square roots.
y=-x/(1+x) = -1+1/(x+1) . Is it true that y>-1 whenever x>-1?
Oh no, I just realized I have made so many mistakes while writing out the reply.
Correct.
EDIT: the condition is ##\frac {1+x} {1+y} \gt 0 ##.
Still, not fully clear on inequality/condition part.
What condition ? (1+x)/(1+y) is always greater than zero if y=-x/(1+x) . Is it possible that x=-10, for example?
The starting equation is valid only when the expressions under the square roots are not negative, that is, both x>-1 and y>-1 must hold.
You can choose x>-1, prove that then y>-1.
Your solution can be rewritten as
  • · Replies 21 ·
  • · Replies 105 ·
13K
