Implicit exponential differentiation?
In summary, the homework statement is to find an equation of the tangent line to the curve xe^y+ye^x=1 at point (0,1). The Attempt at a Solution is to find slope=(-e-1) using the product rule and the chain rule.
jrjack
111
Find an equation of the tangent line to the curve xe^y+ye^x=1 at point (0,1).
I do not recall seeing the Implicit Function Theroem before, I even went back in my book (Stewart Calculus 6th) to check. I found this post but it does not help me understand the steps involved: https://www.physicsforums.com/showthread.php?t=79275
[tex]xe^{y}+ye^{x}=1[/tex]
[tex]\frac{d}{dx}(xe^{y})+\frac{d}{dx}(ye^{x})=\frac{d}{dx}(1)[/tex]
I am not sure if this requires the product rule but,
[tex]\frac{d}{dx}(xe^{y})=e^{y}+xe^{y}[/tex]
Then, I'm not sure on the other part?
[tex]\frac{d}{dx}(ye^{x})=y'e^{x}+ye^{x}[/tex]
Don't forget the chain rule.
[tex]\frac{d}{dx}(e^{y})=e^{y} y'[/tex].
Yes, the point is that if fx(x,y) and/or fy(x,y) are not 0 in a 'hood of (0,1), where y=f(x), or x=f(y) , depending on whether fx or fy is non-zero. The standard example ( I know of) , is that of the sphere.
why can't i use product rule?
Both parts require the product rule. So, of course you need it. You will need the chain rule too.
Yes, I now realize I need to use both rules.
So,
[tex]\frac{d}{dx}(ye^{x})=ye^{x}+y'e^{x}[/tex]
giving me,
[tex]xe^{y}y'+e^y+ye^{x}+e^{x}y'=0[/tex]
[tex]y'(xe^{y}+e^{x})=-e^{y}-ye^{x}[/tex]
[tex]y'=\frac{-e^{y}-ye^{x}}{xe^{y}+e^{x}}[/tex]
at point (0,1).
slope=(-e-1)
jrjack said:
So,
giving me,
at point (0,1).
slope=(-e-1)
Seems ok to me.
Thank you for your help.
1. What is implicit exponential differentiation?
Implicit exponential differentiation is a mathematical technique used to find the derivative of a function that involves both exponential and non-exponential terms.
2. Why is implicit exponential differentiation important?
Implicit exponential differentiation is important because it allows us to find the rate of change of a function that cannot be easily solved using traditional methods. It is commonly used in fields such as physics, engineering, and economics.
3. How do you perform implicit exponential differentiation?
To perform implicit exponential differentiation, you need to use the chain rule, product rule, and quotient rule to differentiate the exponential and non-exponential terms separately. Then, combine the two derivatives to get the final result.
4. What are the applications of implicit exponential differentiation?
Implicit exponential differentiation has various applications, including finding the velocity and acceleration of an object in motion, determining the growth rate of a population, and analyzing the behavior of financial investments.
5. Can implicit exponential differentiation be used for any function?
Yes, implicit exponential differentiation can be used for any function that involves both exponential and non-exponential terms. However, it may become more complex for functions with multiple variables or higher-order derivatives.
