Importance of Current density?
The discussion centers on the significance of electrical current density over total electrical current in electrical engineering. Current density, defined as current per unit area, is essential for analyzing local properties and complex distributions of current, particularly in contexts like magnetic field calculations within materials. While total current is a scalar quantity representing the overall flow, current density is a vector that provides a more nuanced understanding of electrical behavior in specific areas. This distinction is crucial for solving problems involving spatially varying currents, such as eddy currents.
  • Understanding of electrical engineering principles
  • Familiarity with vector calculus
  • Knowledge of Maxwell's equations
  • Basic concepts of magnetic fields and current flow
  • Study the mathematical formulation of current density in relation to Maxwell's equations
  • Explore the implications of current density in electromagnetic theory
  • Investigate applications of current density in materials science
  • Learn about eddy currents and their dependence on spatially varying current densities
Electrical engineers, physicists, and students studying electromagnetism or materials science will benefit from this discussion, particularly those interested in the applications of current density in practical scenarios.
Rajeswar Panja
Why we do use electrical current density in place of total electrical current? Actually I want to know what is the advantage of using electrical current density?
Yes, I read on wiki article but my question is that why we do use current density which means current/unit area rather than the total current?
We don't always use Current Density. In fact, in many years of EE, Current Density hasn't figured very highly in any of my work. Talk to a power Engineer and you may get a different answer.
What is the context of your question?
We use whichever one we need for a given problem
Current density is a vector, current is a scalar?
Current density is a local property (For a point), whereas current is a global property (e.g. for an entire wire). Both are useful depending on the problem but I guess I'll talk a bit more about current density. Densities in general are useful because they allow you to look at the effect of complicated distributions of the quantity in question (e.g. current,charge,mass) by adding up all the little current densities (Numerically or otherwise), current density allows you to find for instance the magnetic field inside a complicated material where only parts of the current have an effect. Another motivation for using densities is that the differential forms of equations, (e.g. Maxwell equations) are more mathematically convenient to work with, and they have to be expressed in terms of local properties.
Both current and current density are vectors i.e. they both have direction but currents are rarely written in vector form probably because they're written too often and it's assumed obvious
Current is in fact a scalar. The current through a surface S (e.g. a cross-section of a wire) is defined as $$I = \iint_S \vec J \cdot d\vec S$$ where ##\vec J## is the current density at each point on the surface and ##d \vec S## is the infinitesimal surface element at that point.
Perhaps an example would help: You can't make any progress on eddy currents without solving for the spatially varying current density.
  • · Replies 28 ·
  • · Replies 29 ·
