Important to know what is myth and propaganda
  • Level: High School
  • Thread starter Thread starter Gil Lee
    Important
12 replies · 2K views
Gil Lee
To learn the real physics, you need to know what is myth and propaganda. For example, How high can you jump on the moon? Understanding Physics, we can estimate the height and the friction to the boot against the ground. Having the correct Physics, you can tell which one Hollywood like the movie is v.s. The realistic way the astronaut walks on the moon.
Welcome to the PF. :smile:
Did you have a question?
Yes. Do you believe the Apollo video shows the realistic way of human walking on the 1/6 gravity vacuum environment?
Do you think a tree looks like a realistic tree?
The videos show humans walking in a 1/6 gravity vacuum environment with heavy suits (the vacuum is irrelevant, apart from making space suits necessary). It can't be more realistic than that.
Are you suggesting there is some problem with the videos of the moon landings and excursions?
(Please re-read the PF rules under INFO at the top of the page, while I reach slowly for the BanHammer...)
What research have you done and what math/physics do you know? You can construct relatively simple scenarios and come up with a serviceable answer. Some structure, research direction to get you going:
1. What is the mass of a typical astronaut?
2. What is the mass of a lunar spacesuit?
3. What is the average force your legs can apply in a rapid leg-press (jump)?
4. What is the distance of a leg press?
5. What is force times distance? (both the relevant name and the answer to the suggested problem)
6. What type of energy do you have at the top of your jump? What's the equation?
7. Set the two equations equal to each other and solve for height.
When the gravity is 1/6, that means the friction between boot and the ground will be about 1/6. The walker feels it is very slippery. Do you know how to walk on the slippery surface? Like cheetah put their center of gravity much forward than the rear legs which are the thrust, you need to incline the human body forward before you start walking or running. When you stop, you need to incline your body backward to reduce the speed just like the man walking on ice. Think about it. Nasa's contracted out to Ph.D. to make the simulator and the video looks totally different from Apollo video.
We have most of the parameter. Nasa said the astronaut weight is about 80lb, and the suit is 80 lb. The astronaut can jump up about one foot on the earth. Using the same muscle, how high can he jump up at 1/6 gravity? Mass is same on the moon, but the weight that counter the muscle is 1/6/
This does not make any sense. Friction is also dependent on the material, and here we talk about sand. If your argument was true, and it is not, then kiddies couldn't walk on the beach, which is definitely wrong.
Neither of those are correct according to common sense and a 5 second Google. Please do better.
I gave you an approach to follow. We can help, but we don't spoon feed. This isn't an answer desk it is an educational forum. Make an effort and if you have specific issues following the approach, ask specific questions.
Queue the music...
You have an approach that seems to be wrong. Guess what. I calculated that astronaut can jump up at least 6 feet on the moon surface. Noen of them jumps that high in Apollo video.
This was enough of misinformation, derailed topics and moon landing conspiracy. I had to remove some of them, because they had been below the standards we try to achieve and were against our rules (see section Moon landing hoax conspiracy theories).
Thread closed.
