Impulse - I am suspecting a wrong answer on the key.
  • Thread starter Thread starter ajdrausal
    Impulse
The correct magnitude of the impulse exerted on a 2.4-kg ball by the floor, after it falls with a speed of 2.5 m/s and rebounds at 1.5 m/s, is 9.6 N/s. The calculation involves determining the change in momentum using the formula I = Δp = mΔv. The correct approach requires considering the final velocity as negative due to the coordinate system where downward is positive, leading to a total impulse calculation of 9.6 N/s.
  • Understanding of impulse and momentum concepts
  • Familiarity with the formula I = Δp = mΔv
  • Knowledge of vector signs in physics
  • Basic algebra for calculating changes in momentum
  • Study the concept of impulse in physics
  • Learn about momentum conservation in collisions
  • Practice problems involving impulse and momentum calculations
  • Explore the effects of coordinate systems on vector calculations
Students studying physics, educators teaching mechanics, and anyone interested in understanding impulse and momentum in real-world applications.
ajdrausal
Impulse -- I am suspecting a wrong answer on the key.
A 2.4-kg ball falling vertically hits the floor with a speed of 2.5 m/s and rebounds with a speed of 1.5 m/s. What is the magnitude of the impulse exerted on the ball by the floor?
* 9.6N/s
* 2.4N/s
* 6.4N/s
* 1.6N/s
* 1.0N/s
Answer key says 9.6N/s
My calculations say 2.4N/s
Impulse = ∆Momentum
∆Momentum = mv(Initial) - mv(final)
∆Momentum = (2.4kg)(2.5m/s) - (2.4kg)(1.5m/s)
∆Momentum = 6 - 3.6 = 2.4 N/s
What is the right way of doing this?
That is a cute question.
I=Δp=mΔv
You have Δv wrong (sign error).
Δv=(-2.5-1.5)m/s
Do this for practice
A 40 000 Kg sled is sliding towards you at 50 m/s what impulse do you need to apply to change its velocity to
a)49.999 m/s towards you
b)49.999 m/s away from you
I=Δp=mΔv
Δv=(-2.5-1.5)m/s
So then
Impulse = ∆Momentum
So the v(final) should be negative (my coordinate plane being down as the positive direction)
then
∆Momentum = (2.4kg)(2.5m/s) - (2.4kg)( - 1.5m/s)
which gives me
∆Momentum = 6 + 3.6 = 9.6
Thanks!
  • · Replies 19 ·
  • · Replies 24 ·
