Impulse Momentum Method for Rotational
6 replies · 2K views · last reply
freshbox
For impulse momentum, I know that collision between two object, impulse = 0.
Can somebody explain to me how come for this question the impulse is 0 "shaft A engaged to shaft b" has the same meaning as collision?
And I assume that it is right for me to add shaft A and shaft b moment of inertia together in order to solve the question but can somebody explain the reason behind it?Thanks a lot.
  • Multiple-choice physics question text: Shaft A, moment of inertia 1.26 kg m^2, rotating at 598 rpm clockwise; shaft B, moment of inertia 0.9 kg m^2, rotating at 410 rpm in same direction; common angular velocity after slipping ceases in rad/s. Options 54.4, 179, 18.6, 519.7.
Thanks a lot.
impulse momentum = angular momentum. For a rigid body, angular momentum = (moment of inertia) multiplied by the (angular velocity ω).
In a collision of point masses, the momentum (mv) stays constant. In case of interaction between rigid bodies, the moment of inertia stays constant if there is no external torque.
The two shafts rotates around the same axis, but slipping one on the other. That is some interaction between them, like in a collision. The interaction will speed up the rotation of the faster shaft and slow down the rotation of the other one, till they both rotate with the same angular velocity.
The angular momentum of a system can change if some external torque acts on it. There is no external torque in this case, so the sum of the angular momenta of the shafts stays constant.
ehild
You need an external force F which is not parallel to the axis of rotation and its line does not go through the axis. You get the torque τ as force times the length of its arm d, τ=Fd. The "arm" is the distance of the line of force from the axis. When you push a door open, you exert a torque on it. The door interacts with the hinge, but your force causes an external torque.
ehild
  • Diagram of a rod pivoting at its lower end, with a horizontal force F pointing left applied at its upper end, and the perpendicular distance d marked from the pivot to the line of force; labelled tau = Fd.
Thank you ehild. For the next question, how do you determine which momentum is -ve or +ve? Bigger momentum = +ve?
  • Multiple-choice physics question: a 400-kg boxcar at 50 m/s couples with a 940-kg boxcar at 125 m/s in the opposite direction; options 146.3, 72.8, 343.8, 102.6.
In this problem you decide which direction you take positive. You can choose the greater one.
ehild
