Impulse momentum theorum with a spring
The discussion centers on calculating the time a 700 g air-track glider is in contact with a spring during a collision. The key equation used is the impulse-momentum theorem, expressed as F(t1-t2) = mv2 - mv1. The correct approach involves using the average force rather than the peak force, with the area of the triangle representing the force over time calculated as A = 0.5 * (36 N) * Δt. The final solution indicates that the change in time is approximately 0.116 seconds, derived from the correct application of the impulse-momentum theorem.
  • Understanding of the impulse-momentum theorem
  • Knowledge of basic physics concepts such as force, mass, and velocity
  • Ability to calculate the area of a triangle
  • Familiarity with unit conversions (grams to kilograms)
  • Study the concept of average force in impulse calculations
  • Learn how to derive the area under a force-time graph
  • Explore the implications of momentum conservation in collisions
  • Review examples of impulse-momentum problems in physics textbooks
Students studying physics, particularly those focusing on mechanics and dynamics, as well as educators looking for examples of impulse-momentum applications in real-world scenarios.
powerofsamson
A 700 g air-track glider collides with a spring at one end of the track. The figure shows the glider's velocity and the force exerted on the glider by the spring.
How long is the glider in contact with the spring?
F(t_1-t_2)=mv_2-mv_1
I have the force as 36N, v_1 as -3, v_2 as 3.
When I plug this into the equation I get
change in t = (700*3-700*(-3))/36=116.6
I know this has to be wrong but I'm confused which variable I have wrong. Maybe the force?
You need to convert 700 g to kg. Other than that, I think your solution is correct.
change in t = ((.7*3)-(.7*-3))/36 = .116 s is also wrong.
Sorry, you need to use the average force. The 36 N is the peak force.
I'm still stuck on this one. I know that i can calculate avg force by impulse / change in time, but I'm not sure how to find avg force in this situation.
In case anyone else has a similar problem I'll explain how I found the answer. I found the area of the triangle with. A = .5 * (36, force max) * change in t. A is equal to weight in kg * v_1 - (weight in kg * v_2). Therefore 4.2 = .5 (36) * change in t.
I know this is an old message but this poster states he solved the problem by finding.
(simply restating correct solution posted in quotes here)
A=area
A=.5(Fmax)Δt
A=mv1-mv2
I think? I don't understand what equations the poster was trying to write out.
Wouldn't the change in momentum be zero since the final and initial speeds are equal?
Or would it be double the current momentum because of the change in direction?
  • · Replies 19 ·
