Impulse on ball involving angles
The discussion focuses on calculating the impulse and average force exerted on a 0.40 kg ball that is initially moving at -20 m/s and is then kicked to a velocity of 30 m/s at a 45-degree angle. The impulse is determined to be 18.5 kg-m/s, calculated using the change in momentum derived from the horizontal and vertical components of the velocity. The average force is subsequently calculated as 1850 N, based on the impulse and the collision time of 0.010 seconds. The importance of treating momentum and velocity as vectors is emphasized throughout the discussion.
  • Understanding of impulse and momentum concepts
  • Knowledge of vector decomposition in physics
  • Familiarity with Pythagorean theorem for vector magnitude calculation
  • Basic skills in algebra for manipulating equations
  • Study vector decomposition techniques in physics
  • Learn about impulse-momentum theorem applications
  • Explore examples of calculating forces in collisions
  • Review problems involving angles in projectile motion
Physics students, educators, and anyone interested in understanding the dynamics of collisions and vector analysis in mechanics.
AdamNailor
1. A ball of mass 0.40kg is moving to the left at a velocity v0=-20 m/s. It is kicked and given a velocity, at 45 degrees upwards to the right, of vf30[/sub] m/s.
1) Find the impulse of the force
2) Find the average force
The collision time is 0.010s
2. I = (delta) P
I = F (delta)t
3.
1) before p = 0.4x-20= -8
after 30x0.4=12
Change in p = 20Ns Where do the angles some in?
2) F=(delta)P/t=2000
Which is obviously wrong. They didn't include the angles for fun, so there something wrong in my working. Do I have to choose a line to work out the momentum across? ie, linear momentum. A bit confused. Any help appreciated.
Momentum and velocity are vectors and must be treated as such.
\Delta \vec{v} = \vec{v}_f - \vec{v}_i
Hint: Break the vectors into components, then subtract them. That's where the angles come in.
OK, so, 30cos45=21.2
21.2-(-20)=41.2
correct?
21.2-(-20)=41.2
correct?
So far, so good. You've correctly found the change in the horizontal component of the velocity. What about the vertical component? (Then find the magnitude of the total change in velocity.)
well, sin 45 and cos45 are the same, so the vertical change is just sin45=21.2
So the total change in velocity is the total of the two, 21.2+41.2=62.4
So no to find the change in momentum I times 62.4 by the mass to get 24.96 ? which is the impulse?
AdamNailor said:
well, sin 45 and cos45 are the same. so, the change is just sin45=21.2
OK, the change in the vertical component of velocity is 21.2 - 0 = 21.2.
No, you can't just add horizontal and vertical components of a vector. How do you find the magnitude of a vector from its components?
Pythagorus. So \sqrt{41.2^2+21.2^2}=46.3
so I = 46.3x0.4 = 18.5
Good. (Impulse will have the same units as momentum, thus kg-m/s.)
And my working out tghe average force will be correct with this new value? ie,
F=18.5/0.01=1850N.
Thanks for you help btw. This has got to be handed in in 20 minutes! Worth 25 marks too. Silly really for how easy it is, once you've got started, I'm just too hungover to think properly and needed a nudge to get going. Not even sure there are 25 stages in the question to mark.
F=18.5/0.01=1850N.
Looks good.
  • · Replies 19 ·
  • · Replies 24 ·
