Impulse Problem: Find Mass, Height & Impulse
  • Thread starter Thread starter chocolatelover
    Impulse
A ball with a mass of 0.110 kg is dropped from a height of 1.25 m and rebounds to a height of 0.800 m, prompting a discussion on calculating the impulse imparted by the floor. The correct formula for impulse is clarified as J = Δp, with the need for precise definitions involving calculus for exact values. An initial attempt at calculating impulse using the integral of force over time is presented, but the results indicate a misunderstanding in the application of the equations. The conversation emphasizes the importance of correctly applying the impulse formula and understanding the relationship between force, time, and momentum change. Accurate calculations and definitions are essential for solving the problem effectively.
chocolatelover
A ball of mass .110 kg is dropped from rest from a height of 1.25 m. It rebounds from the floor to reach a height of .800 m. What impulse was given to the ball by the floor?
I=ΣFΔt
Δp=I
Could someone please tell me if this is the correct formula?
Thank you very much
Hi chocolatelover! Both of your equations look right but need some minor tweaking.
For starters (I have no clue why, but...) the symbol for impulse is a capitol J.
So J = Δp for instance.
Your first equation should be extended a bit more.
J = ΣFΔt would give you an approximation for impulse however if you wanted the exact value of J you would need to make Δt -> 0, and sum up an infinite number tiny bits force.
A more concrete definition would be J = \int_{t_i}^{t_f}{F dt}
Thank you very much
Does this look right?
integral from 1.25 to .800 (.110kg)(9.8m/s^2)dt
=.8624-1.35
=-.4876
Thank you very much
  • · Replies 24 ·
  • · Replies 19 ·
