Graduate In light of new evidence, what might be behind the Casimir Effect?
Garret Moddel's recent experiment explores the Casimir Effect, demonstrating the generation of current potentially from quantum vacuum fluctuations using a specific conductor-insulator configuration. The setup involves a Casimir cavity that blocks certain wavelengths, creating an asymmetry that allows for the excitation of electrons in a thin upper electrode. The discussion raises questions about the nature of virtual particles and their ability to produce real effects, particularly how quantum fluctuations can lead to observable phenomena like current generation. There is speculation on whether a modified Casimir cavity could yield similar results, emphasizing the need for further understanding of the underlying mechanisms. Overall, the conversation highlights the complexities of quantum mechanics and the implications of Moddel's findings for future research.
  • #31
"Our basic MIM device consists of a thin metal upper electrode, a thin insulator, and a thicker metal lower electrode. Illumination of the upper electrode
metal produces hot carriers,
  • #32
peterbb said:
There is no "light" shining on the device.
Yes, there is. From the lower left-hand column of the first page:
Photoinjection occurs when electromagnetic radiation incident on an absorber excites hot charge carriers...
"Electromagnetic radiation incident on an absorber" means coming from the outside, i.e., from light shining on the absorber. If there is no light shining, there is no incident radiation.
From the top of the right-hand column of the first page:
Illumination of the upper electrode metal produces hot carriers...
Unless there is a light shining on the metal, there is no "illumination".
  • #33
peterbb said:
This is a IV curve plotted against an externally applied voltage
Where in the paper does it say there is an externally applied voltage? Be specific.
  • #34
Ah okay I see where I can clarify here. Yes, you're right. There is light, in that sense. However, the "light" is coming from ZPF (zero point fluctuations), that's the whole point! The paper is making the point that the device seems to be internally illuminated via ZPF as a result of placing attaching a Casimir cavity to it.
Due to the all the other reasonable possible sources being ruled out, it seems logical to conclude that ZPFs are likely responsible for the illumination.
First two sentences of the abstract:
The differential conductance of metal-insulator-metal devices increases when they are joined with Casimir cavities. An imbalance in injection of hot charge carriers from each side of the insulator is increased with thinner cavities that suppress more quantum vacuum modes.
^ Here they are talking about the hot charge carriers increasing with thinner cavities, due to the Casimir effect suppressing more vacuum modes. That's your light source.
cont'd abstract:
The result is an observed increase in conductance. Additional conductance changes, with insulator thickness and other device parameters, are consistent with an imbalance-induced injection of hot carriers. In addition to the conductance changes, we observe anomalous offsets in the current and voltage. We interpret the conductance changes in terms of a 𝚫E𝚫t uncertainty principle-like limit to the injection of hot carriers from zero-point fluctuations.
Repeating from my my previous post: It's in the paper's supplementary material. Page 4. Second sentence. It mentions the name of configuration they used to assess the resistance of the device. The technique is called the four point probe technique. If you google this you will see this technique always has a power supply attached to it on the outer two probes. That power supply is needed in order to generate the I-V curve. Vary the power supply and check voltage, plot, repeat, etc.
  • #35
That's not what the specific passages I quoted say. They say there is an external light source.
So that means there is another external source of energy, namely, the power supply.
Likes hutchphd
  • #36
PeterDonis said:
The presence of the conductors at the boundary of the cavity restricts the quantum field modes that are available inside the cavity, as compared to a free vacuum with no restriction on available modes. The fewer modes that are available, the lower the ground state energy of the vacuum.
This is the standard narrative. The problem with it is that it perpetuates the misleading picture that Casimir effect originates from vacuum energy.
  • #37
What is your take on the mechanism of the Casimir effect?
Likes Demystifier
  • #39
Demystifier said:
I read the abstract of the first and the whole pdf of the second. My mathematics and quantum physics are not advanced enough to be able to understand the proofs. But I am familiar with van der Waals. I can see how intuitively van der Waals can explain the effect. What are your thoughts given the findings of the paper cited in this thread (and, for the record, there is no light shining on it, otherwise it would not be an anomaly worth publishing - it is producing its own energy internally through some mechanism according to the IV curve).
  • #40
I can see how one might come to the conclusion by taking a sentence out of context. If you read the first two paragraphs it places things in context. There is no external light source. Again, by ruling out all other possibilities, it is reasonable to conclude that the illumination is coming from within the device, likely via quantum fluctuations. That's why illumination and photo-injection is talked about extensively. There's no light shining on it from the outside. Then there would be no "anomaly".
(for anyone who's reading this without context, please read my earlier reply where I explain the role of the power supply in IV graphs, and about the (V=0, I=0) intersection in detail).
Correct - there is an external source of energy, the power supply. That's needed to make an IV curve. With a non-power generating resistor, you expect the line to go through the origin. In this case, it takes 0.07mv to stop the current. This is not possible unless the device is producing its own energy somehow (or getting it from somewhere else - but the 8 culprits mentioned were accounted for - there may be others of course, and there is no light shining on it).
I've created a visual to explain this using the figure in the paper. Note how the green line passes through the origin when V=0. This is how a non-power generating device behaves. In our case, there is a positive current even when V is negative.
Again, it's not so much the I > 0 when V = 0, it's that there are data points within the 2nd quadrant, demonstrating that there is positive current when external voltage is applied against the flow of current.
  • #41
I don't have much thoughts on it, the paper is purely experimental, while I'm a theorist.
  • #42
I have read these repeatedly and I'm not getting that. I'm getting that there is an external light source. But even if I am wrong and you are correct, that's still not the primary issue. See below.
No, with a completely dissipating resistor, you expect the line to go through the origin. In other words, a resistor does not convert any input power into current. Apparently the devices used in this experiment do. But that doesn't mean they are generating power from nowhere. They are generating power, if they are doing so at all, from the input provided by the power supply. With no power supply hooked up, the thing just sits there and doesn't generate anything. At least, that would be my expectation--but the people who ran this experiment did not even think of running this obvious control experiment.
To really test what these experimenters are claiming to test, you would hook up a circuit to the device containing a tiny load, with voltage and current measurements attached to the load (or part of the load), but with no power supply at all, and see what happens. A device that can actually generate power "from the vacuum" would show a nonzero voltage and current under such conditions, which the load would use for whatever it does. I predict that the devices in this experiment would do no such thing. But in any case this is an obvious thing to do which these experimenters did not do. Again, that makes me highly skeptical that they are showing a real effect, rather than an artifact of the fact that their experimental setup contains a power supply.
  • #43
In this paper there are detailed specs of all the relevant raw data to reproduce the experiment: the dimensions of the parts of the device, thickness, materials, even fabrication methods, and other extra data like refraction index.
If they were shining a light on it, they would include details about the spectrum of light, intensity, distance, angle, etc. You don't find any of this information in the paper, because they are not shining a light on it.
Further down the paper, below Fig 4:
For an MIM device in equilibrium, any carriers excited by ZPFs and injected into the insulator from the upper electrode would be balanced by ZPF-excited hot carriers from the base electrode. We hypothesize that the presence of the Casimir cavity breaks this balance, resulting in a change in the net injection rate and hence increased G. This imbalance is discussed in greater detail after the presentation of the results. Because cavities suppress zero-point electromagnetic modes having wavelengths greater than twice the cavity thickness, reducing the cavity thickness increases the range of suppressed wavelengths. We would therefore expect an increase in G for decreasing cavity thickness, a trend that can be seen in Fig. 3(b).
Examining the results of Fig. 3(b) further, we would expect wavelengths in the visible range to dominate the response because, for near-UV wavelengths <250nm, the PMMA becomes highly absorptive [40], and the infrared response is limited because the available vacuum energy density falls off with the cube of the wavelength. Although the vacuum energy density in ideal Casimir cavities varies inversely with the thickness cubed [7], we would not expect the conductance to exhibit such a cubic dependence because there are multiple energy-dependent mechanisms in play, including (i) variations of photoinjection yield with photon energy, as described by extensions of Fowler's theory of photoemission [41]; (ii) the interband transition threshold of Pd [42], which limits the transport of high-energy carriers; (iii) the energy-dependent reflectivity of the mirrors and absorptivity of the transparent dielectric; and (iv) the energy dependence of hot carrier scattering [43].
I hope this makes it really clear that the photo-injection the paper is referring to is explicitly from zero-point fluctuations in the electromagnetic field. They are not shining a light on it.
  • #44
The IV curve is more informative and comprehensive than doing a power load test because it gives a broader insight as to its behaviour and characteristics, max power output (at which voltage), etc. Using these values you can calculate how it would behave with a resistor alone, and a lot more. You get the open-circuit voltage, short-circuit current, maximum power point, and others that would be more relevant if it were not linear. With a simple load test you get more of a "snapshot", but with IV curve you got a whole spectrum of information.
In this case it's linear so it's quite simple. Still, it gives a clearer picture, and we know that it's linear.
I think you're right that it would be more intuitive for people without less technical background to prefer to see a simple resistor and voltage measurement. I personally would like to see that as well, but it doesn't change the fact that that information can be garnered from the IV curve.
Thank you for staying in the conversation.
  • #45
Perhaps it is for "standard" components. But this paper is claiming that the device in question is anything but a "standard" component. So appealing to the normal behavior and usage of an IV curve is not valid in this case. A claim like "this device can generate power from the vacuum with no energy input" should be tested directly. This test is not a direct test since there is energy input (even if we leave aside the light source question, there is a power supply).
  • #46
In many circumstances the IV curve is used because the the slope is a immune from the issues of where the origin is exactly. It turns out that because of temperature dependent contact potentials and a host of other complications in layered structures finding these zeros is fraught. These folks seem to infer far more than is reasonable from the data presented.
Likes Lord Jestocost
  • #47
Since the discussion has died down, and since the paper is questionable, this thread is now tied off. If there are new papers with validations of the results by other groups, please PM a Mentor to either reopen this thread or allow a new thread to be started. Thanks folks.
Likes hutchphd
  • · Replies 25 ·
