Inclined Surface: Velocity and angle of incline
The angle of incline directly affects the acceleration of a car moving down a slope due to gravitational potential energy (PE). As the angle increases, the component of gravitational force acting parallel to the incline increases, leading to greater acceleration. The relationship between height and the length of the incline can be expressed as h = length * sin(θ). The velocity of the car can be determined using the equation v = √(2gh), where g is the acceleration due to gravity. Understanding these relationships is crucial for solving problems related to motion on inclined planes.
Svensken
How is angle of incline related to the acceleration of the car moving down it?
I know how to find both the velocity and acceleration of a car moving down a track using the suvat equations. I don't understand the relationship between angle of incline, velocity and gravity.
Basically, how does increased gravitational PE affect velocity?
mgh
2s/t=v
I think it has something to do with cosine of the angle as well as 1/2mv^2
Thank you guys and Gals!
Spit the weight of the car into components perpendicular to the plane and parallel to the plane.
Also, how would you find the height the car is at when you know the length of the incline?
i was thinking:
mgh turns into 1/2 mv^2 (i am neglecting friction)
rearranging gives
v = sqroot(2gh)
Since g is equal to acceleration due to gravity it becomes g =a*sin(angle)
Is this correct?
Svensken said:
i was thinking:
rearranging gives
v = sqroot(2gh)
yes but say you only had the length of the incline and the angle θ, what would h in terms of that length and θ?
Is this correct?
This is correct for the car's acceleration parallel to the plane
i would assume that h= length*sinθ?
Parallel meaning moving down the plane?
Thanks mate!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
