Including Boost filesystem.hpp in C++
  • Topic: C/C++
  • Thread starter Thread starter Jamin2112
    Boost C++ Program
3 replies · 2K views
Jamin2112
I've changed the Library Search Path to the folder that contains the file I'm trying to use, filesystem.hpp, and then including the file with the directive #include <filesystem.hpp>. I've also tried changing it to "filesystem.hpp"; changing the search to recursive; trying to grab it from the folder 1 level above in the directory by changing the search path 1 level above and changing the directive to #include <boost/filestysem.hpp>, #include "boost/filestysem.hpp", etc.
Hopefully the following screenshots can show you where I'm at.
Any suggestions about what I can try to fix this?
Here is an "imaginary" guideline :DD. Use this with your own risk.
1. Download Boost and extract it into your favorite folder.
2. Check the xxxboostxxx.sh file to see if its version to be installed matches with one you would want to build.
3. Run it ./xxxboostxxx.sh, after which the BOOST environment variable will be created.
4. Create your build settings in XCode (you can use the attachments below then fix the versions of gcc/g++ compiler and boost).
OTHER_LDFLAGS = $(BOOST)/lib/libboost_system-xgcc48-mt-$(BOOST_VERSION)-macosx.a
HEADER_SEARCH_PATHS = $(inherited) $(BOOST)/include/boost-$(BOOST_VERSION)/
LIBRARY_SEARCH_PATHS = $(inherited) $(BOOST)/lib
BOOST_VERSION = 1_57
Done.
It doesn't. Should I change the VERSION variable accordingly?
Am I supposed to use a modified version of that script and is supposed to be self-explanatory which portions I need to modify for my own use?
I may have detected my problem. I'm trying to use the Filesystem library and it says here that Filesystem requires a separate build.
