Independent elements of matrices?
The discussion focuses on the concept of independent elements in symmetric and antisymmetric matrices, specifically Ar and Ai, as described in the article linked. It is established that only the lower triangular elements of the symmetric matrix Ar are independent, while the strictly lower triangular elements of the antisymmetric matrix Ai are independent, with diagonal elements being zero. The term "independent" refers to the mathematical definition, indicating that there are no equations enforcing relationships among these elements, allowing them to vary freely.
  • Understanding of symmetric and antisymmetric matrices
  • Familiarity with linear algebra concepts, particularly matrix theory
  • Knowledge of matrix independence and its mathematical implications
  • Ability to interpret mathematical articles and equations
  • Study the properties of symmetric matrices in linear algebra
  • Learn about antisymmetric matrices and their applications
  • Explore the concept of matrix independence in greater depth
  • Review the implications of zero diagonal elements in antisymmetric matrices
Mathematicians, students of linear algebra, and anyone involved in theoretical physics or engineering who seeks to understand matrix properties and their implications in various applications.
perplexabot
Hey all. I am currently reading an article and there is a paragraph that I am having a hard time understand. This is what the paragraph says:
"Since Ar = Arτ and Ai = -Aiτ, we know that only the lower triangular (including the diagonal) elements of Ar are independent and only the strictly lower triangular (excluding the diagonal) elements of Ai are independent."
I don't exactly know what "independent elements" means in this case.
Are we talking about algebraic independence (because linear independence makes no sense to me in this case)? If yes, can someone please provide some insight into how it applies in this case? I read about algebraic independence on wiki, so I do have a general picture of what it is.
If you would like to refer to the article, here it is: http://www.ee.ucr.edu/~yhua/MILCOM_2013_Reprint.pdf
The paragraph is located under equation 9 of page 4 of the pdf.
Thank you PF.
If Ar and Ai have been derived by a process that forced them to be symetric and antisymetric, then Ar(i,j) ≡ Ar(j,i). for all (i,j) So once the elements above the diagonal are given, the elements below the diagonal are known. Same for the antisymetric matrix Ai, where Ai(i,j) ≡ -Ai(j,i) for all (i,l). For Ai we also know that Ai(i,i) ≡ 0.
So that gives a lot of equations that Ar and Ai must satisfy.
Likes perplexabot
OK, I think I get what you mean. So they are using less elements in order to describe the same set of equation(s). I wonder why the diagonal isn't included for Ai?
So this "independent" is just the everyday English definition, right?
Because Ai(j,j) = -Ai(j,j) we know that Ai(j,j) =0. So the diagonal elements are not free.
It also has the mathematical meaning. There are no equations forcing a relationship between them. They are all mathematically independent of each other.
Likes perplexabot
Thank you for the quick responses and easy to understand explanation.
I should have figured out that the diagonals are zeros, silly me (i didn't see it in your first post either). Thank you for that. Not exactly sure what you mean by "not free" tho?
What is meant by "them" here?
Apologies for my many questions, hopefully you can be patient with me.
I also have a question in this same article but about something different. You think I should open a new thread?
EDIT: I think I get why the diagonal pf Ai isn't included now. Since it is zero it really doesn't contribute to the equations, is this right?
(regarding the diagonal elements of Ai) Maybe I need to be more careful in my terminology. I meant that you can not assign any value you want to them. They must be 0.
(regarding the elements below the diagonal) All the elements below the diagonal can take any value without any relationship to the other elements below the diagonal.
The diagonal elements must be 0 for the equations to work. So they "contribute" in that sense. The definition of antisymetric forces the diagonal elements to be 0.
Likes perplexabot
I got it! Thank you!
  • · Replies 17 ·
9K
