Can indirect searches for DM provide insights into candidate particles?
  • Context: Graduate
  • Thread starter Thread starter ChrisVer
The discussion focuses on indirect searches for dark matter (DM), specifically examining the challenges in identifying candidate particles such as neutralinos and axions based on observed bursts of rays. It highlights that axions, due to their low mass, do not appear in high-energy particle detections, while heavier candidates like neutralinos do. The conversation also emphasizes the importance of understanding the mass, decay products, and interactions of dark matter particles to narrow down the search parameters. Additionally, the use of microwave cavities for direct searches of axions is noted as a prominent method.
  • Understanding of dark matter particle candidates (e.g., neutralinos, axions, sterile neutrinos)
  • Familiarity with particle detection methods (e.g., indirect and direct searches)
  • Knowledge of energy scales relevant to particle physics
  • Basic concepts of photon interactions and cosmic microwave background (CMB)
  • Research the properties and detection methods for neutralinos in high-energy physics
  • Explore microwave cavity techniques for detecting axions in cosmological studies
  • Investigate the role of sterile neutrinos in dark matter theories
  • Learn about the implications of the cosmic microwave background on dark matter detection
Physicists, researchers in particle astrophysics, and anyone involved in dark matter research will benefit from this discussion, particularly those focusing on detection methods and particle identification in cosmological contexts.
ChrisVer
In general, the indirect searches for DM consist of looking at a burst of rays coming from somewhere in the Universe.
Is that correct? Is there any other way?
However, I am not sure how can someone , after seeing such a burst, decide whether it comes from candidate X (let's say neutralino) or candidate Y (let's say axion). Also how are we looking at such a thing [devices/physics]?
Space news on Phys.org
Axions have very low masses, while neutralinos have much higher masses. So axions won't show up in high-energy particle detections but neutralinos (or any other thermally-produced dark matter particle) will.
I guess then I should have said some other heavy candidate ,my bad for choosing axions, could I ask the same for sterile neutrinos?
Or is it that you can't distinguish between them, but you have the knowledge then at which energy scale to look into the laboratory [for direct searches]?
Is that correct? I
No. Some of these detectors aren't even directional.
Meaning? I didn't mean at a specific direction...
Well, basically the main thing that you'd get is a small piece of the whole picture. The main questions to be answered are:
1. What is the mass of the dark matter particle?
2. What does it decay into?
3. What are its interactions with other matter?
Any observation of dark matter helps to narrow the parameter space available. The ratio of dark matter to normal matter combined with the observation that it's relatively low in temperature give constraints on these quantities, and getting even a little bit of other data would dramatically limit the available options.
In general I am trying to write/suggest 2 experimental (1 direct and 1 indirect) ways to search for Dark Matter.
I'm pretty sure about the direct searches, and how to explain them, for almost every popular DM candidate...
However I feel kind of "weak" when it comes to indirect searches.
My idea was to take some particular particle, let's say axions. For the direct searches, the microwave cavities are the most renowned ways for looking into cosmological axions, with which you can look at the open axion-window and get their mass and virial velocity dispersion. Such a signal would be the discovery of the axion.
However the axion can also give photons through the coupling to 2 gammas. So if the axion appears to have (let's say) m_a \approx 0.1 ~ meV would we see a gamma rays coming from some "dark" region with E_\gamma \approx 0.05 ~meV ? But isn't that like direct seeing the axion decay?
A photon with 0.1meV of energy would have a wavelength of a little more than 1cm. This is just a bit higher in frequency than the peak frequency of the CMB. Photons of this energy would probably be drowned out by the incredibly bright CMB.
  • · Replies 57 ·
