Induced current from changing magnetic field
iharuyuki
Diagram of a rectangular wire loop beside a long straight wire labelled i(t), with the loop's sides marked a, b, c, d, the distance z, and side length L; text lists R_a = R_c = 150 ohms and R_b = R_d = 75 ohms, plus a homework question part c).
emf = i (induced) R
emf = - d(Ф)/dt
Ф = B (dot) A
B = μi/(4piR)
emf = - d(Ф)/dt
emf = - d( B (dot) A )/dt
emf = - d[ (μi/(4piR) * A ]/dt, A and B are perpendicular
Really not sure how to proceed from here as there are multiple derivatives (di/dt dR/dt and dA/dt) that I don't quite get.
Thank you very much.
You have to calculate the total flux φ through the loop. Since B is a function of R, you have to integrate to find the total flux, which will be a function of i. In terms of your question about time derivatives, the only thing changing with time is i. A and R are constant in time.
