Induced emf generation problem
4 replies · 9K views · last reply
mbrmbrg
In Figure 30-52 (see attached), a metal rod is forced to move with constant velocity v along two parallel metal rails, connected with a strip of metal at one end. A magnetic field B = 0.370 T points out of the page.
(a) If the rails are separated by 26.0 cm and the speed of the rod is 65.0 cm/s, what emf is generated?
[tex]\phi_B=\oint \vec{B}\cdot d\vec{A}[/tex]
[tex]\varepsilon=-\frac{d\phi_B}{dt}[/tex]
[tex]v=\dot{x}[/tex]
I got the correct numerical answer, just my sign is off for part a.
[tex]\varepsilon=-\frac{\vec{B}\cdot d\vec{A}}{dt}[/tex]
[tex]\varepsilon=-\frac{BLdx}{dt}[/tex]
[tex]\varepsilon=-BLv[/tex]
[tex]\varepsilon=-(0.370T)(0.26m)(0.65m/s)[/tex]
[tex]\varepsilon=-0.00625V[/tex]
Book says there is no negative in the final answer.:confused:
  • Diagram of a metal rod with velocity v to the left, sliding along two parallel rails in a region of dots showing a magnetic field B out of the page, with separation L marked.
The minus sign in Faraday's law tells you that the direction of induced EMF opposes the change in flux. But all they want is the magnitude, which is positive. (If they wanted the direction, you'd have to specify clockwise or counterclockwise per Lenz's law.)
What in the problem should tip me off that they want only magnitude?
Also, what is the meaning of direction of emf? Is it the direction of the induced field lines?
That they didn't ask for direction? :smile: (Sorry!) But realize that a negative answer doesn't mean much.
You can specify the direction in terms of the direction of the induced current the EMF would drive. What would the direction of the EMF/induced current be in this problem?
Read this (especially the section on Lenz's law): http://hyperphysics.phy-astr.gsu.edu/hbase/electric/farlaw.html"
:redface: Hmmm... I thought that unless otherwise specified, a direction was expected.
Oh. OK. I figured out that the current should be clockwise (which the problem states to be the negative direction), so the direction of the emf is clockwise/negative, as well.
