Induction Motor Auto-Transformer Starter - Power and Torque
10 replies · 4K views · last reply
Stu80
Describe an auto-transformer starter. From the expression for power
input per phase (∝ torque) show that for a turns ratio (n) of √3:1 , for
the auto-transformer:
Three bulleted formulas: power input to the motor per phase equals V_s squared times R_p over n squared times Z_p squared; motor starting torque equals direct on-line torque over 3; star/delta starter torque matches the auto-transformer.
Pin (phase) = 3 V I cos∅
I = V/Z
cos∅ = R/Z
T∝I∧2
T∝V∧2
For auto transformer with ration n:1, V=V/n, I=nI, T∝1/n∧2
I don't understand the question fully, what would be my starting expression? Pin (phase) = 3 V I cos∅?
How do I relate this to being proportional to torque?
I presume in the expression for the power input to the motor/phase that the resistance and impedance is that of the phase with them being denoted with a p?
I've atempted a number of solutions by substituting I and cos∅ for V/Z and R/Z respectively into Pin (phase) = 3 V I cos∅ but I don't come out with anything relevant.
Could you help me get started please?
  • Three bulleted formulas: power input to the motor per phase equals V_s squared times R_p over n squared times Z_p squared; motor starting torque equals direct on-line torque over 3; star/delta starter torque matches the auto-transformer.
input per phase
Has your text given you a formula for "power input per phase " that includes terms Rp and Zp ?
No unfortunately it hasn’t, what I posted in the problem statement is everything I have.
i agree it isn't clearly stated .
i don't think you have to prove that because they already told you "the expression for power input per phase (whatever that is-jh) is (∝ torque) "
i think that's safe to assume.
what else do we know?
We know that a motor has resistance and inductance
so we might express the impedance Z of a phase as R +jXL.
And do we know that apparent power = V2/Z ? If not, check that out with Ohm's Law.
And do we know that R/Z = cosine Φ ? If not, check that out with Pythagoras.
Hmmm. Might that awful looking fraction break down into something less fearsome?
Equation shown in red-outlined box: P = Vs²Rp / (n²Zp²), with V subscript s squared times R subscript p over n squared times Z subscript p squared.
Break it into a product of individual terms and see if anything logical falls out...
##\frac{1} {n}## X ## \frac {1}{n}## X V X ## \frac {V} {Z} ## X ## \frac {R} {Z}##now ignore the 1/n 's for a moment and concentrate on what's left
does it resemble VIcosΦ ?
Now what to do with those n's ?
why the 3 ?
Grad students who write the homework problems for textbook authors often leave clues for you to decipher just like in a mystery novel.
Always take a close look at what they give you and ask "Why did he say that " ?
And, take just one thought step at a time.
Here in homework forums we're not supposed to give you the answer, instead to lead your thoughts toward it.
To that end i just went back to very basics .
Basics rock ... Trust them !
old jim
"Never trust a computer with anything important."
  • Equation shown in red-outlined box: P = Vs²Rp / (n²Zp²), with V subscript s squared times R subscript p over n squared times Z subscript p squared.
Thanks for replying Jim, here's what I have snipped from MS Word:
Handwritten-style derivation of input power for an auto-transformer: Pin p = Vs Ip cos θ, with Ip = Vs/Zp and cos θ = Rp/Zp, giving Pin p = Vs × Vs/Zp × Rp/Zp; for turns ratio n:1, Vs = Vs/n, ending in the highlighted result Pin p = Vs² Rp / (n² Zp²).
Please let me know if it looks good.
  • Handwritten-style derivation of primary input power for an auto-transformer: Pin p = Vs Ip cos θ, then substituting I = V/Z and cos θ = R/Z, then for turns ratio n:1 with Vs = V/n, ending at Pin p = Vs² Rp / (n² Zp²).
  • Handwritten-style derivation of input power for an auto-transformer: Pin p = Vs Ip cos θ, with Ip = Vs/Zp and cos θ = Rp/Zp, giving Pin p = Vs × Vs/Zp × Rp/Zp; for turns ratio n:1, Vs = Vs/n, ending in the highlighted result Pin p = Vs² Rp / (n² Zp²).
Aha ! Same exact thing we figured out up above. from the basics.
But what MS Word document is that from? Your text ?
So what happens to that expression for power when you insert the turns ratio √3 ?
Might it make sense to divide the terms at the two applied voltages?
That's often a handy little algebra trick that reduces the number of unknowns.
It's my MS Word document, I'm just writing the answer to the question up, I find it easier to type it up in the equation editor in word as opposed to the text box provided.
I'm not sure I understand your comment, I thought I was simply proving the final equation or do I have to go a step further and substitute the (√3)^2 which would obviously replace the n^2 with 3?
For the next two parts of the question I have the following:
Handwritten-style typed working: torque T is proportional to V squared; for an auto-transformer with turns ratio n:1, Vs = V/n and T = T/n squared, giving T = T/(√3)² = T/3; for a star/delta starter, the same result T/(√3)² = T/3 is reached, matching the auto-transformer.
  • Handwritten-style typed working: torque T is proportional to V squared; for an auto-transformer with turns ratio n:1, Vs = V/n and T = T/n squared, giving T = T/(√3)² = T/3; for a star/delta starter, the same result T/(√3)² = T/3 is reached, matching the auto-transformer.
I think you have now answered all three of the questions in your original post.
Bravo !
you might annotate your snip with comments
to help you remember should teacher ask you to explain it to class.
Be ready to clarify why cosine of current angle is the same as .cosine of impedance angle Rp/Zp.
I would rehearse a blackboard demonstration "just in case".
That might sound vain, but if he doesn't ask you don't have to admit to it.
Boy Scout's Motto "Be Prepared"
old jim
Sorry for the late reply - Thank you for all your help Jim.
You're welcome.
Did we get it right ? Did teacher have you work it on the blackboard ?
old jim
