How to Complete the Inductive Step in a Series Inequality Proof?
  • Thread starter Thread starter sbc824
    Proof
The forum discussion focuses on completing the inductive step in proving the series inequality \(\sum_{i=1}^{n}\frac{1}{i^2} \leq 2 - \frac{1}{n}\). The user has successfully completed the base and assumption steps but is struggling with the inductive step. To advance, they need to show that \(\sum_{i=1}^{k}\frac{1}{i^2} + \frac{1}{(k+1)^2} \leq 2 - \frac{1}{(k+1)}\). The key insight is to combine terms and leverage known inequalities to finalize the proof.
  • Understanding of mathematical induction
  • Familiarity with series and summation notation
  • Knowledge of inequalities in mathematical proofs
  • Basic algebraic manipulation skills
  • Study the principles of mathematical induction in depth
  • Learn about series convergence and divergence, particularly \(\sum_{i=1}^{n}\frac{1}{i^2}\)
  • Practice proving inequalities using induction with examples
  • Explore advanced algebraic techniques for manipulating inequalities
Students and educators in mathematics, particularly those studying calculus or real analysis, as well as anyone interested in mastering proof techniques involving inequalities.
sbc824
i=1 Sigma n (1/i2) <= 2 - (1/n)
I've done the basic step and assumption step...little stuck on the inductive step
So far I have...
show 1 + 1/4 + 1/9 + 1/16 +...+ (1/k2) + (1/(k+1)2) <= 2 - (1/k+1)
So far I have...
To clarify matters:
I take it that you need to prove (by induction) that:
\displaystyle <br /> \sum_{i=1}^{n}\frac{1}{i^2}\le2-\frac{1}{n}\ .​
Is that correct?
So, you have assumed that 1 + 1/4 + 1/9 + 1/16 +...+ (1/k2) ≤ 2 - (1/k) ,
and you need to show that 1 + 1/4 + 1/9 + 1/16 +...+ (1/k2) + (1/(k+1)2) ≤ 2 - (1/(k+1)) .
Is that correct?
What have you tried, in this effort?
BTW: Please learn to use parentheses, so that your mathematical expressions say what you mean for them to say.
SammyS said:
To clarify matters:
Is that correct?
Is that correct?
Yes, that is correct...I've done equality inductive proofs, but have not encountered less than or greater than type proofs...so I'm not sure how to begin.
The idea is almost exactly the same as equality. Starting from where you left off you have \sum_{i=1}^{n}\frac{1}{i^2} + \frac{1}{n+1}≤ 2- \frac{1}{n+1}
See what happens if you combine like terms and use what you already know about \sum_{i=1}^{n}\frac{1}{i^2} to help you out.
Let's see:
You are assuming that some k,
1 + 1/4 + 1/9 + 1/16 +...+ 1/k2 ≤ 2 - (1/k) .​
Adding 1/(k+1)2 to both sides gives you that
1 + 1/4 + 1/9 + 1/16 +...+ 1/k2 + 1/(k+1)2 ≤ 2 - (1/k) +1/(k+1)2 .​
So, if you can show that 2 - (1/k) +1/(k+1)2 ≤ 2 - 1/(k+1), then you should be able to complete the proof.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 24 ·
