Industrial electronics. Question with coils and diode.
48 replies · 7K views
Femme_physics
http://img198.imageshack.us/img198/1421/vintm.jpg
Given that k = 2
A) Draw in a qualitative manner the following letters
Vin, VP, Vs, Uxy, UR1, UR2, UD
B) Calculate the power in R2
C) Calculate the average current through R1
I'll start with a little theory. The way I see it there are 2 currents, one marked in blue and one marked in green. The current marked in red actually gets stuck, so it appeared no current hits the second circuit. Could it be?
http://img8.imageshack.us/img8/6656/mkkkmkkkk.jpg
Consider that voltage on the primary of the transformer is a sinusoid, so it has positive and negative excursions. Similarly, the voltage across the secondary will also have positive and negative excursions and follows a sinusoidal function.
In the secondary circuit, as you surmised, the diode will block current flow when the secondary's voltage causes the diode to be reverse biased. So, perhaps you could sketch the anticipated current function for the secondary circuit for a full cycle. How would you represent this function mathematically? (HINT: you might want to break the function into more than one time interval).
Morning Fp! :smile:
What do you mean by: "Given that k = 2"?
I suspect that when they asked to draw the letters in a qualitive manner, they meant as a graph, with the amplitude on the vertical axis, and the time on the horizontal axis.
Do you know how to draw for instance Vin in this manner (this looks like a sinusoid)?
I like your drawing with the blue and green arrows, which is exactly what happens. :)
And yes, in the right circuit the current following the red arrow is blocked, but as gneill already suggested, in the reverse direction it will still flow.
Hi gneil! Morning ILS :smile:
Oh, I thought it's understood that k is "transmission relation of the transformer", which is basically i1/i2 or u1/u2 or n1/n1 (I'm still not sure what's N1/N2)...
To my understand coil Vp only transforms the current in one direction, no? The direction I drew in red. I do understand there are two directions for current flow, that's why I drew the one in green and blue
I'm not sure. Can the current go like this?
http://img855.imageshack.us/img855/3387/vpvs.jpg
Ah, thanks for clearing it up :smile:
I suspected as much, although I'm still not clear which coil has the most windings.
Do you know?
As you can see the letters P and S are used.
Those stand for "primary" coil and "secondary" coil.
n1 and n2, or N1 and N2 are the number of windings in each coil.
Although in this case I'd prefer Np and Ns to eliminate the ambiguity.
So is k = Ns / Np?
Or is k = Np / Ns?
Actually, the coils do not so much transform current, but they transform voltage (in both directions).
And due to the voltage the current will flow (if it can).
In the primary circuit the current will flow in both directions, while in the secondary circuit it will only flow in one direction due to the diode.
Yes, it can. :)
So is k = Ns / Np?
Or is k = Np / Ns?
Good question! Can anyone help with it? I wish I knew!
But your preference of using Np and Ns is better IMO :smile:
Do you know?
Well, the question doesn't say so
Makes sense :approve:
Yes, it can. :)
So what's the point of the dots in the coil? u see? one Vp dot and one Vs dot? Do you see the dots I'm talking about?
Let's assume k=Np/Ns, because usually a transformer transforms the voltage from high to low.
(Like in the adapter for your laptop, where it is transformed from 230 V to 12 V.)
I believe the dots are only markers to indicate the points where they would like you to make a qualitative drawing of the voltage (in the form of a graph with an x-axis and an y-axis).
Femme_physics said:
This is my idea of Vin after reading the replies
I'm almost seeing a smile. :smile:
I'm afraid the voltage of Vin does not make jumps.
It's just a fluent sine curve, it has to be since it's supposed to be a perfect voltage source.
Makes sense
I was thinking it had more significance than that, but I guess I had it wrong. Oh well.
:biggrin:
Doesn't it depends at what loop we're looking at? But if not, I guess it should be: (ignore lack of symmetry!)
http://img812.imageshack.us/img812/1227/secondtryy.jpg
Ignoring lack of symmetry... yep! :)
Btw, do you know how high the tops are?
Well, there's
U(av)
and
U(rms)
and
U(max)
I think what's given to me is U(max) so I'd venture to say the tops are U(max)
i.e. 230V
but they ask to draw it in a qualitative manner, so that means without numbers no?
As far as Vp and Vs...
http://img42.imageshack.us/img42/2459/booooooz.jpg
once again ignoring symmetry heh... :smile:
Femme_physics said:
Well, there's
U(av)
and
U(rms)
and
U(max)
Hmm, I don't know U(av). What is that?
I can tell you that U(rms) is given - I believe it usually is.
I'm not sure, what "qualitative" means exactly.
It think it means that you should not do calculations, but I think it does (or should) include which numbers go where.
Anyway, after the graphs they are asking for numbers, so I think it's a good thing if you're already aware of how the numbers apply to the graphs.
I see you've taken the smile-version of the sliced sine graph. :)
However, I'm afraid you're too early slicing it off.
The induced voltage in the secondary coil is still the full voltage, positive and negative.
I'm afraid that's how induced voltage (also known as electromotive force or emf) works.
If you want I can give a longer explanation, based on the related magnetic field.
You should take into consideration that Vs is on the side of the coil that has fewer windings, which has an impact on the amplitude.
http://img808.imageshack.us/img808/7753/mizzz.jpg
Fair enough :smile: makes sense.
oh heh, that's how it's called?^^
Oh, you're right, I was thinking "circuit", I wasn't thinking "coils". So Vs is the same as Vp (as I've drawn Vp)
Femme_physics said:
Aaah, "av" stands for "average".
Oh, well, that one is not usually used.
Anyway, I know those formulas slightly differently:
[tex]U_{av} = \frac {2U_{max}} {\pi}[/tex]
[tex]U_{rms} = \frac {U_{max}} {\sqrt 2}[/tex]
so your U(max) is not right yet.
Where did you get your formulas?
Almost, but not quite.
Vs is on the coil with fewer windings...
From my textbook! I swear it says it... so it's wrong?
A bigger hint, maybe?^^
Errr... yes, it is wrong assuming U(rms) and U(max) are voltages.
There is an alternate formula:
[tex]P_{rms} = \frac {P_{max}} {2}[/tex]
This is about power, instead of voltage.
Perhaps that one was intended?
Btw, the symbol U is also used for energy, although that seems to be misplaced here.
But that might almost be applicable.
You wrote before:
So I assumed you knew...
[tex]\frac {Vs} {Vp} = \frac {Ns} {Np}[/tex]
Well my textbook definitely says U and not P. But I'll ask my lecturer, for sure.
[/QUOTE]
Well, I'm now reading the comments section of the question and it says
"If both the points are in the same place, the transformer keeps the phase. If both points are in a different location, the transformer reverses the phase. I don't know what it means by "reverses the phase"..hopefully I'm translating it correctly. "
It also tells me that: "The directing of the winding determines the current's direction. If it's the same winding directon, it'll be the same direction of current. Although it doesn't say here the direction of the winding. Do I read it from the sketch?
It does not appear to be given in the sketch or in the problem statement.
My choice would be to assume the winding direction is the same, meaning the direction of the current is the same.
But since they do not specify both choices would be correct.
As always you have a "voltage difference".
On the top of the coil the voltage goes up and then down (relative to the bottom or some zero in the middle).
But at the bottom of the coil the voltage goes down and then up (relative to the top or some zero in the middle).
This is what they call "reversed phase".
(Note that with reverse winding, this would also reverse the phase.)
Btw, since this information about winding direction and points is given in the comments section, that makes me reconsider the meaning of the dots.
Now I think the dots symbolize that the phase is reversed.
I have to admit that I was not aware of such a convention.
That means that when Vp goes up, Vs goes down.
And when Vp goes down, Vs goes up.
I was told it's true for "where AC current passes through a single diode creates a half wave rectified sine"
but I guess since what we have is a more complicated circuit your formulas apply? I just don't see them on the manual.
So it really should be:
http://img600.imageshack.us/img600/4651/umaxxy.jpg
I guess I'll add it to my notes then
Aha! So in that case, this is wrong
Should be
http://img171.imageshack.us/img171/136/reallyshould.jpg
Not quite.
Edited:
When an AC current passes through a diode you would have:
Vrms(after) = Vrms(before) / √2
since effectively only part of the voltage (half of the power) comes through.
The Vmax however is unchanged.
Note that the given relation between Vmax and Vrms is only true when we're talking about a sine wave.
No, it's not about a more complicated circuit.
It's about the relation between "max" and "rms" when we're talking about a sine wave.
Yes.
Always a good thing. :)
In this case we can conclude that the construction is such that the phase reverses.
This would for instance happen if the coils are inside each other with a reverse winding.
Should be
Yes, but this is only when the current in the primary circuit is flowing as you indicated.
It will still also flow the other way.
Vrms(after) = Vrms(before) / 2
since efffectively only half of the voltage comes through.
rms voltage means root-mean square of the time-dependent periodic voltage. It is connected to the power: The average power of the AC voltage is the same as that of a DC voltage, equal to the rms value of AC. The power is proportional to the square of the voltage: That means that the time-average of the square of voltage for a period is
[tex]V_{rms}^2=\frac{1}{T}\int_0^T{V(t)^2dt}[/tex]
If it is a full wave, V=Vmaxsin(wt)
so
[tex]V_{rms}^2=\frac{1}{T}\int_0^T{V_{max}^2s in^2(w t)dt}[/tex]
As sin2 (wt)=1/2(1-cos(2wt), the integral of cos (2wt) cancels, and
[tex]V_{rms}^2=\frac{1}{2}V_{max}^2[/tex] ,
Vrms=Vmax/√2
If the voltage is zero during half period, the integral is half than before (and the power is half, too):
[tex]V_{rms}^2=\frac{1}{T}\int_0^{T/2}{V_{max}^2 sin^2(w t)dt}=\frac{V_{max}^2}{4}[/tex]
Vrms2(half-wave)=Vrms2(full wave)/2. The half wave produces half the power of the full wave, so the Vrms(half wave)=Vrms(full wave)/√2
ehild
@Fp: Can you now draw the graph for Vs?
It should have a lower amplitude than Vp, and it should have a reversed phase.
A couple of comments.
Conventionally the turns ratio of a transformer is defined to be the ratio of secondary turns to primary turns, n = Ns/Np. Whether or not FP's k value follows this convention is something that she should check with her text or class notes.
Also conventionally, for AC circuits a voltage source is usually taken to be given in RMS volts unless otherwise specified. Again, FP should check to see what convention is being used in her class.
I'm sorry I'm still quite confused with respect to these formula:
http://img7.imageshack.us/img7/2083/umaxyman.jpg
I'm really not sure which formulas to use (the one you provided or the ones provided to me) until I figure that little tidbit out. You seem to have edited something but I'm not sure what!
I'll check, thanks :smile: sent my lecturer email just now.
Yes the value is given to us in rms. :smile: that's what my notes say.
You can see my original text in the quote that is contained in ehild's post.
I only changed 2 into √2 to make it true, and I adjusted the text to match.
I can imagine.
I can't make sense of these formulas either. :confused:
Can you provide some contextual information on what u(t) represents?
And what U(max) represents?
As far as I can tell, the only way these formulas can be true, is if these symbols are defined differently than what I'm expecting.
As I expect them, the top formula for U(av) should be zero, and the bottom formula for U(rms) is basically the same as the formulas ehild posted - just with a different result!
Hey Fp, goodmorning! :smile:
Do you need a better hint?
Since we have a k=2, which presumable transforms the primary voltage to a lower secondary voltage, the amplitude of Vs would be half of Vp.
Since Vs is reversed in phase with respect to Vp, Vs would be negative when Vp is positive and Vs would be positive when Vp is negative.
