Inelastic collision involving pulley
4 replies · 2K views · last reply
issacnewton
Here is the problem I am trying
Two blocks A and B of same mass M are connected with
each other with an ideal string of length [itex]2l[/itex] passing over an
ideal pulley. The block A is connected to a light pan C
with an ideal string as shown in figure. A particle of mass
[itex]\frac{M}{2}[/itex] is dropped on pan from height
[itex]\frac{l}{2}[/itex] as shown. If
collision between particle and pan is plastic, acceleration
of B just after the collision is
a) [itex]g[/itex]
b) [itex]\frac{g}{9}[/itex]
c) [itex]2g[/itex]
d) none of above
I have attached the snapshot of the problem. Now, I am thinking on the following lines. Since
the pan is light, when the mass M/2 falls on it, the string attached to the pan will feel the jerk.
And we can think of mass M/2 attached to the pan and accelerating downwards with acceleration g. Do you think this is a good starting point ? I am not sure if my reasoning is correct here...
thanks
IssacNewton said:
Since
You don't think the pan and attached masses will reduce the acceleration at all?
Try doing the free body diagrams for the three masses when M/2 has reached the pan.
I don't know if IssacNewton is willing to continue the thread but I would like to understand how to solve this. How did the OP conclude that the acceleration of the pan is g, is this even correct? Basically, how should I approach this problem?
Sorry for late reply. I thought that since falling mass is going to hit the pan, its acceleration would be g. Probably this is wrong.
It's g before it hits the pan of course, but that's not what we want to know.
This is rather a curious problem. I don't know whether it intends to confuse by supplying irrelevant information, but it certainly does that.
It asks for the accelerations just after hitting the pan, not the velocities. So here's a question: do the velocities immediately after impact affect the forces at that time? If not, the history doesn't matter: we can just look at the free body diagram after impact, and not even care that an impact occurred.
