Infinite Sequences of Sines
  • Context: Undergrad
  • Thread starter Thread starter Euge
    Infinite Sequences
The discussion revolves around the existence of a strictly increasing sequence of integers \( m_1 < m_2 < m_3 < \cdots \) such that for all positive integers \( \ell \), the sequence \( \sin(\ell m_1), \sin(\ell m_2), \sin(\ell m_3), \ldots \) converges. The scope includes mathematical reasoning and exploration of sequences related to the sine function.
  • Some participants propose specific integer sequences, such as \( m_n = [\pi \cdot 10^{n-1}] \), suggesting they may converge to zero.
  • Others argue that convergence is not guaranteed, citing the dependence on the decimal expansion of \( \pi \) which does not converge.
  • A participant suggests using rational approximations of \( \pi \) to construct the sequence, listing several fractions as potential candidates.
  • Another idea involves using the periodicity of the sine function and the Bolzano-Weierstrass theorem to find a convergent subsequence.
  • Some participants discuss the implications of interpreting the angles in radians versus degrees, noting that the latter leads to trivial solutions.
  • There is a suggestion to explore the partial convergents of the continued fraction for \( \pi \) as a method to find the sequence.
  • Several participants express uncertainty about whether the convergence must be to zero or if other limits are acceptable.
  • One participant emphasizes the need to derive a solution for any \( \ell \) rather than just for \( \ell = 1 \).
  • Another participant mentions the graphical approach to understanding the problem, focusing on the periodic nature of the sine function.
Participants express a range of views on the construction of the sequence and the conditions for convergence. There is no consensus on the specific sequence or the nature of convergence required, indicating multiple competing views remain.
Some discussions highlight the difficulty in proving certain properties related to the density of the rationals and the implications of the choice of integers in the sequence. The requirement for the integers to be strictly increasing adds complexity to the proposed solutions.
Euge
MHB
POTW Director
Prove the existence of a strictly increasing sequence ##m_1 < m_2 < m_3 < \cdots## of integers satisfying the property that for all positive integers ##\ell##, the sequence ##\sin(\ell m_1), \sin(\ell m_2), \sin (\ell m_3),\ldots## converges.
It is just a conjecture but
[tex]m_1=3[/tex]
[tex]m_2=31[/tex]
[tex]m_3=314[/tex]
[tex]m_n=[\pi*10^{n-1}][/tex]
may satisfy the statement with convergence to zero. Is it so ?
Why would you get convergence? The fraction you are losing depends on the nth digit of the decimal expansion of pi, which doesn't converge.
Sure, my bad. Thanks.
Another attempt is to find better rational number approximations of ##\pi## by computer,
[tex]\frac{3}{1}, \frac{22}{7},\frac{355}{113},\frac{3550}{1130},\frac{99733}{31746},\frac{833719}{265381},\frac{5419351}{1725033},\frac{80143857}{25510582},...[/tex]
which are the best ones with both numerator and denominator are under ##10^n##. I made series of the numerators,
[tex]m_1=3,m_2=22,m_3=355,m_4=3550,m_5=99733,m_6=833719,m_7=5419351,m_8=80143857,...[/tex]
xsinx
3​
0.141120008​
22​
-0.008851309​
355​
-3.01444E-05​
3550​
0.000301444​
99733​
-0.000380862​
833719​
2.31292E-06​
5419351​
-3.82004E-08​
80143857​
-1.47741E-08​
sin x are small but I am afraid it is not enough for the statement.
Say integers a, b are
[tex]\frac{b}{a}=\pi+\epsilon[/tex]
[tex]\sin(bl)=\sin(al\epsilon)[/tex]
Regard them as sequence, so that ##b_n## be what we want, we must show
[tex]a_n \epsilon_n \rightarrow 0[/tex]
I hope to find a good approximation sequence satisfying it. Diophantine approximation https://en.wikipedia.org/wiki/Diophantine_approximation seems to assure the existence of such a sequence, but I have no idea how to construct it actually.
I assume you mean radians? If it were interpreted as degrees it would have the trivial solution ##sin(l m_i ) = 0## for all ##l, m_i =360 i## with ##i= 1 ,2,3...∞## converging to zero.
  • Sad
Does strictly increasing mean just each term larger or each term larger according to some algorithm? Can the integers be arbitrary as long as they are larger?
A strictly increasing sequence is a sequence where each term is larger that the previous term. Nothing more than that.
My idea is to exploit the periodicity of the sine function by considering [itex]x_m = \ell m \mod 2\pi[/itex] as a sequence in [itex][0,2\pi][/itex] and using Bolzano-Weierstrass to extract a convergent subsequence [itex]x_{m_n} \to x \in [0,2\pi][/itex]. Then by continuity of the sine function, [itex]\sin(\ell m_n) = \sin(x_{m_n}) \to \sin x[/itex].
Unfortunately that shows "for every positive integer [itex]\ell[/itex] there exists a sequence of strictly inreasing integers [itex]m_n[/itex]" and we require the reverse, so there is more work to be done.
A sequence can be obtained using the density of the rationals.
Find a sequence first for ##l =1##, then show the same sequence works for any ##l##.
Yes, it is in radians.
The strictly increasing sequence is expressed in the problem statement: ##m_1 < m_2 < m_3 < \cdots##. Thus ##m_2## is larger than ##m_1##, ##m_3## is larger than ##m_2##, and so on.
I think one must derive a solution for any ##\ell## up front. There are an infinite number of sets of ##m_i's## but in general they will not work for any ##\ell## so the way the set of ##m_i's## are generated is the key in my mind. So far I can only think of ways that are not scalable with ##\ell##.
Thanks. The word sequence made me think they must be some consistent algorithm but I understand now it just means list and ##m_{i+1}## need have no relation to ##m_i## except ##m_{i+1}>m_i##.
Not necessarily. Get a solution for ##l =1## first.
I worked out a proof in my head, but something I thought was equivalent to the density of the rationals turns out to be quite difficult to prove!
For positive integer [itex]\ell[/itex], [itex]\sin(\ell m_n)[/itex] is a polynomial of degree [itex]\ell[/itex] in [itex]\sin(m_n)[/itex]. and will therefore converge to a limit if [itex]\sin(m_n)[/itex] does. I think this competes the proof.
pasmith said:
For positive integer [itex]\ell[/itex], [itex]\sin(\ell m_n)[/itex] is a polynomial of degree [itex]\ell[/itex] in [itex]\sin(m_n)[/itex]. and will therefore converge to a limit if [itex]\sin(m_n)[/itex] does. I think this completes the proof.
What is the polynomial?
I think this only works if you choose a potentialy different sequence ##m_n## for each ##l##.
Or, perhaps I got confused by the previous post?
Your idea seems to work simply by:
##\forall m > 0##, let ##x_m \in (0, 2\pi)##, where ##m = 2k\pi + x_m## for some ##k \ge 0##.
By B-W there is a convergent subsequence ##x_{m_n} \to x##, and ##\sin(m_n) = \sin(x_{m_n})## converges by continuity of the sine function. Likewise ##\cos(m_n)## converges.
Finally, ##\forall l##, ##\sin(lx)## can be written as a continuous function of ##\sin(x), \cos(x)##.
Use the Euler formula:$$\sin(lx) = Im[e^{ilx}] = Im[(\cos x + i\sin x)^l]$$
Is it necessary in this problem that convergence means convergence to zero?
Sorry if I'm misunderstanding, but since each term has to be bigger than the last, wouldn't
m1=2π
m2=4π
m3=6π
where
mn=[2nπ]
work?
m_1=2pi
m_2=4pi
m_3=6pi
m_n=[2npi]
work?
The ##m_i's## must be integers.
I had to think of this problem graphically rather than analytically. Using a unit circle and starting with the sine of 1 radian one easily can see how an infinite number of smaller sines can be made by ever larger angles to exploit the periodicity of the sine function as @pasmith said thus generating an infinite set of strictly increasing ##m_i's## chosen such that the sines are all in the positive quadrant and ##\sin(m_i) →0## as ##m_i →∞##
What threw me is the demand ##\ell## be any integer and the ##m_i's## remain the same. Graphically, for an arbitrary ##\ell## this spreads the nicely decreasing sines in the first quadrant into the full circle and the sequence jumps around between minus one and plus one. The sequence could seemingly oscillate forever yet in the limit as ##\ell m_i →∞##, there is still an infinite number of terms in the positive quadrant that converge to zero so the sequence as a whole converges.
First, we need to prove that for any irrational number ##x## and ##\epsilon > 0##, there exist integers ##k, n## such that ##|kx - n| < \epsilon##. I thought this would follow from the density of the rationals, but I haven't found a proof yet.
Let's assume that holds. And, in particular, applies to ##\pi##.
Note that for every ##m > 0##, we have the closest integer mutiple of ##\pi## (##n_m\pi##) and the minimum distance from ##m## to multiples of ##\pi## (##d_m = |m - n_m\pi|##).
We choose ##\epsilon_1 = \frac 1 {10}## and ##\epsilon_{i+1} = min\{\frac 1 {10^{i+1}}, d_1 \dots d_{m_i}\}##. Where ##m_i## is chosen so that ##|m_i -n_{m_i}\pi| = d_{m_i} < \epsilon_i##.
Involving all the previous ##d_i## (all positive integers up to ##m_i##) ensures we have a strictly increasing sequence ##m_i##.
Then, as ##\epsilon_i## is small, we have ##|\sin(m_i)| = |\sin(m_i - n_{m_i}\pi)| < |m_i - n_{m_i}\pi| < \epsilon_i \le \frac 1 {10^i}##.
And, we see that ##\sin(m_i) \to 0##.
Finally, we can use the same argument with cosines and polynomial functions to show that for any ##l## we have ##\sin(lm_i) \to 0##.
But, we still need a proof of the initial lemma.
This can be cleaned up further: I missed that for positive integer [itex]\ell[/itex] we have simply [itex]\sin(\ell m_n) = \sin(\ell x_{m_n}) \to \sin(\ell x)[/itex].
Is this statement true? Here's a heuristic argument casting doubt:
Let ##x = \pi##, for simplicity. We can assume, wlog, that ##\epsilon < 1##, Then the expression becomes ##|k\pi - n| < \epsilon < 1##. That implies that ##n = [k\pi]##, the greatest integer less than ##k\pi##. Thus, ##|k\pi - [k\pi]|## is the fractional part of ##k\pi##. If we use base k, then ##k\pi## is the base-k expansion of ##\pi##, shifted by one digit. Saying that this number is less than any ##\epsilon > 0## would be like saying that the base-k expansion of ##\pi##, shifted by one, has a sequence with arbitrarily many zeros. That's not known.
##k, n## depend on ##\epsilon##. If the same ##k,n## suffice for all ##\epsilon##, then we must have ##k\pi = n##, which is impossible.
  • · Replies 17 ·
