Infinite Sequences of Sines
  • Context: Undergrad
  • Thread starter Thread starter Euge
    Infinite Sequences
The discussion revolves around the existence of a strictly increasing sequence of integers \( m_1 < m_2 < m_3 < \cdots \) such that for all positive integers \( \ell \), the sequence \( \sin(\ell m_1), \sin(\ell m_2), \sin(\ell m_3), \ldots \) converges. The scope includes mathematical reasoning and exploration of sequences related to the sine function.
  • Some participants propose specific integer sequences, such as \( m_n = [\pi \cdot 10^{n-1}] \), suggesting they may converge to zero.
  • Others argue that convergence is not guaranteed, citing the dependence on the decimal expansion of \( \pi \) which does not converge.
  • A participant suggests using rational approximations of \( \pi \) to construct the sequence, listing several fractions as potential candidates.
  • Another idea involves using the periodicity of the sine function and the Bolzano-Weierstrass theorem to find a convergent subsequence.
  • Some participants discuss the implications of interpreting the angles in radians versus degrees, noting that the latter leads to trivial solutions.
  • There is a suggestion to explore the partial convergents of the continued fraction for \( \pi \) as a method to find the sequence.
  • Several participants express uncertainty about whether the convergence must be to zero or if other limits are acceptable.
  • One participant emphasizes the need to derive a solution for any \( \ell \) rather than just for \( \ell = 1 \).
  • Another participant mentions the graphical approach to understanding the problem, focusing on the periodic nature of the sine function.
Participants express a range of views on the construction of the sequence and the conditions for convergence. There is no consensus on the specific sequence or the nature of convergence required, indicating multiple competing views remain.
Some discussions highlight the difficulty in proving certain properties related to the density of the rationals and the implications of the choice of integers in the sequence. The requirement for the integers to be strictly increasing adds complexity to the proposed solutions.
  • #31
PeroK said:
##k, n## depend on ##\epsilon##. If the same ##k,n## suffice for all ##\epsilon##, then we must have ##k\pi = n##, which is impossible.
Perhaps I should flesh out my argument, since I wasn't assuming that k and n were fixed. Your lemma states, in effect, that given any ##\epsilon > 0##, there exist integers k and n (depending on ##\epsilon##) such that ##|k\pi - n| < \epsilon##. I argue that, if this is true, then there exist sequences of integers ##k_1, k_2, k_3, \cdots## and ##n_1, n_2, n_3, \cdots##, such that
##|k_1\pi - n_1|= 0. 0a_1 a_2 a_3 \dots##
##|k_2\pi - n_2| = 0. 00b_1 b_2 b_3 \dots##
##|k_3\pi - n_3| = 0. 000c_1 c_2 c_3 \dots##
{writing ##k_1## and ##n_1## corresponding to ##\epsilon_1## (as defined below) and so on.
As in my prior post, we may assume that ##\epsilon < 1##. Then, by assumption, there exist integers ##k_{\epsilon}## and ##n_{\epsilon}## such that ##|k_{\epsilon}\pi - n_{\epsilon}| < \epsilon < 1##. Since the difference between ##k_{\epsilon}\pi## and ##n_{\epsilon}## is less than one, we must have that ##n_{\epsilon}## is the integer nearest to ##k_{\epsilon}\pi## and so ##|k_{\epsilon}\pi - n_{\epsilon}|## is the decimal part of ##k_{\epsilon}\pi##. Setting ##\epsilon_1 = 0.1, \epsilon_2 = 0.01##, and so on, we get the sequence shown above. It is unknown whether such a sequence, corresponding to arbitrarily many zeros at the beginning of ##k_i\pi##'s decimal expansion, exists. (I originally included the part about base k to simplify the argument, but it's not needed.)
  • #32
I don't follow that argument. I'm pretty sure that lemma must hold for all irrationals.
  • #33
Here's an outline proof. Let ##x## be a positive irrational and consider the infimum of the set ##S = \{k' = kx -[kx]: k \in \mathbb N \}##. By choosing ##\epsilon < inf S## we can find ##k_1, k_2## such that ##k'_1 - inf S = \epsilon## and ##infS < k'_2## and ##k'_1 - k'_2 < \epsilon##.
Then each ##k_2 -k_1## steps we reduce ##k'## by a fixed quantity less than ##inf S##, which leads to some ##k' < inf S##. Unless, of course, ##\inf S = 0##.
  • #34
What if ##x = 0.101001000100001000001 \cdots##? (with the number of zeros between ones increasing by one each time). That number is clearly irrational, but the set S contains numbers of the form ##0.10 \cdots, 0.0010 \cdots, 0.00010 \cdots## (letting k equal a suitable power of 10) and so on. Therefore, Inf(S) = 0. There are plenty of other irrationals such that Inf(S) = 0. You recognize that's an issue, but how do you handle it? Can you even prove that ##S = \{k' = k\pi -[k\pi]: k \in \mathbb N \}## doesn't have Inf (S)= 0?
  • #35
Here's a full proof:
Let ##x## be a positive irrational and consider the infimum of the set ##S = \{k' = kx -[kx]: k \in \mathbb N \}##. We need to show that ##s = \inf(S) = 0##.
Assume ##0 < s < 1##. We can find ##k_1## such that$$k_1x = n_1 + s + \epsilon$$where ##\epsilon < s## and ##s + \epsilon < 1##.
Now, we can find ##k_2 > k_1## such that $$k_2x = n_2 + s + \delta$$where ##\delta < \frac \epsilon 2##. Note to ensure that ##k_2 > k_1##, we look for ##\delta < \min\{\frac \epsilon 2, 1'-s, 2'-s \dots k'_1-s\}##.
Moreover:$$(2k_2 - k_1)x = 2n_2 + 2s + 2\delta - n_1 - s - \epsilon = 2n_2 - n_1 + s + 2\delta - \epsilon$$This is a contradiction, as$$0 < s + 2\delta - \epsilon < s$$and hence we have a member of ##S## less than the infimum. The conclusion is that ##\inf(S) = 0##, as required.
  • #36
The whole point is that ##\inf(S) = 0## for all irrationals; as I've just proved. And that proves the original lemma.
  • #37
PeroK said:
First, we need to prove that for any irrational number ##x## and ##\epsilon > 0##, there exist integers ##k, n## such that ##|kx - n| < \epsilon##. I thought this would follow from the density of the rationals, but I haven't found a proof yet.
Let's assume that holds. And, in particular, applies to ##\pi##.
But, we still need a proof of the initial lemma.
I don't understand why you needed to prove it for any ##x## instead of just ##\pi## which is what you are interested in using. If you can show you can construct the sequence around ##\pi## then its existence is proved isn't it?
  • #38
It amounted to the same thing. The irrationality of ##\pi## was the key property, so it seemed logical to generalise.
  • #39
I realize the proof does not require it but I'm still interested in seeing an actual algorithm or method to generate the ##m_i's##. I tried but ran into a mental block.
  • #40
Alternative method:
Define [itex]f: \mathbb{N} \to S^1 : m \mapsto (\cos m , \sin m)[/itex]. Then by sequential compactness of [itex]S^1[/itex], [itex](f(m))_{m\in\mathbb{N}}[/itex] has a convergent subsequence [itex](f(m_n))_{n\in\mathbb{N}}[/itex]. Then for positive integer [itex]\ell[/itex] let [tex] P_\ell: S^1 \to S^1 : (\cos \theta, \sin \theta) \mapsto (\cos \ell \theta, \sin \ell \theta)[/tex] which is a polynomial of degree [itex]\ell[/itex] and so continuous. Hence [itex](P_{\ell}\circ f)(m_n) = (\cos(\ell m_n), \sin(\ell m_n))[/itex] converges.
EDIT: I got confused with a different thread concerning convergence of [itex]\sin^2(a_n)[/itex], which has period [itex]\pi[/itex]; however the principle is clear.
Python:
import numpy as np
a = np.zeros(6,dtype=int)
a[0] = 1
xprev = a[0] % np.pi
# Constructing a sequence such that x_{m_n} tends to a multiple of pi:
for n in range(1,6):
    m = a[n-1] + 1
    while True:
        x = m % np.pi
        if min(x, np.pi-x) < min(xprev, np.pi-xprev):
            a[n] = m
            xprev = x
            break
        m = m + 1
a
array([     1,      3,     22,    333,    355, 103993])
np.sin(a)**2
array([7.08073418e-01, 1.99148567e-02, 7.83456762e-05, 7.78129716e-05,
       9.08682039e-10, 3.65931487e-10])
  • #41
There is a little more work to cover the case where ##s \in S##. First, ##s \ne x-[x]##, since ##x- [x], 2x -[2x], 3x-[3x] \dots## cannot increase indefinitely and when it overflows ##1## and decreases we must have ##nx - {nx} < x - [x]##, because ##x- [x]## is effectively the increment each time.
And, if ##s = nx - [nx]##, then we take ##nx## as our starting irrational with the same ##s##, which is impossible, by the above argument.
  • #42
Actually, the above tidy-up gives an idea for a simpler elementary proof. In outline, we start with ##x - [x]##, then find a sequence ##n_k## such that ##n_{k+1}x - [n_{k+1}x] < n_kx - [n_kx]##. This sequence is bounded below, hence converges and hence the difference in terms in the sequence must tend to zero. That gives the required sequence.
  • #43
bob012345 said:
I assume you mean radians? If it were interpreted as degrees it would have the trivial solution ##sin(l m_i ) = 0## for all ##l, m_i =360 i## with ##i= 1 ,2,3...∞## converging to zero.
OP, pls answer this. I was all excited that I found an easy solution.
  • #44
Hi @paige turner, please read post #12.
  • #45
I didn't expect that this POTW would invite so much attention and discussion. Thanks to all for participating!
Since the sequence ##\{\sin n\}_{n = 1}^\infty## is bounded, by the Bolzano Weierstrass theorem it has a convergent subsequence ##\{\sin n_1(k)\}_{k = 1}^\infty##. The sequence ##\{\sin 2n_1(k)\}_{k = 1}^\infty## is bounded, so it admits a further subsequence ##\{\sin 2n_2(k)\}_{k = 1}^\infty##. Continuing the process, we extract a sequence of sequences ##\{n_1(k)\}_{k = 1}^\infty, \{n_2(k)\}_{k = 1}^\infty,\ldots## such that for every positive integer ##\ell## the sequence ##\{\sin \ell n_\ell(k)\}_{k = 1}^\infty## converges. Define ##m_k = n_k(k)## for ##k = 1, 2, 3,\ldots##. Then ##m_1 < m_2 < \cdots##, and given a positive integer ##\ell##, the sequence ##\{\sin \ell m_k\}_{k = 1}^\infty## is eventually a subsequence of the convergent sequence ##\{\sin \ell n_\ell(k)\}_{k = 1}^\infty##, so it converges.
  • · Replies 17 ·
