Infinite series (i think it's riemann)
The discussion revolves around the infinite series \(\sum_{1}^{\infty} \frac{k^2}{n^3+k^2}\), with participants exploring its potential connection to Riemann sums and improper integrals.
  • Participants question the clarity of the original series expression and suggest alternative interpretations, including the possibility of rewriting the sum as an improper integral. There are discussions about bounding the series and the implications of those bounds on the result.
There is an ongoing exploration of the series, with participants offering various interpretations and bounds. Some suggest that careful estimates are necessary to approach the problem, while others express uncertainty about the initial formulation.
Participants note potential confusion in the original statement of the series, indicating that it may require rephrasing for clarity. There is also mention of varying results from calculations, highlighting the need for careful analysis.
flyerpower
[itex]\sum_{1}^{inf}[/itex] k^2/(n^3+k^2)
I think it's Riemann but i cannot find a suitable function to integrate.
Isn't it suppose to be
[tex]\sum_{n = 1}^{\infty} \frac{k^2}{n^3 + k^2}[/tex]
Please take more care to expressing to others (and yourself) what it is you want to find. As written the sum doesn't make total sense. It could be what Susanne217 said above, or Riemann sum comment makes me think you could have also meant [itex]\displaystyle\lim_{n\to\infty} \sum_{k=1}^n \frac{k^2}{n^3 + k^2}[/itex].
I agree...
I have been away for a while but I think it could be that the young man is suppose re-write the sum to an improper integral and thereby finding the sum of the series??
In the case that it is what I thought, then it's not as simple as recognizing it as a pre-prepared Riemann sum. With some careful estimates to bound the sum, you should get the result to be [itex]1/3[/itex].
Isn't it true that you need to rewrite this series into more easy to work with??
First of all sorry for misspelling.
I used the bounds k^2/(n^3+n^2) <= k^2/(n^3+k^2) <= k^2/(n^3+1) and i worked it out to 1/3.
Then I have made a mistake cause it get to be 0.373551 and not a 1/3 :(
I may have been wrong but wolframalpha says it's 1/3 so it must be correct :).
Use those bounds and take the limits, you'll see they both converge to 1/3.
  • · Replies 17 ·
