Inhomogeneous Electromagnetic Wave Equation
1 reply · 7K views
Warr
Consider a medium where [tex]\vec{J_f} = 0[/tex] and [tex]{\rho_f}=0[/tex], but there is a polarization [tex]\vec{P}(\vec{r},t)[/tex]. This polarization is a given function, and not simply proportional to the electric field.
Starting from Maxwell's macroscopic equations, show that the electric field in this medium satisfies the non-homogeneous wave equation:
[tex]{\nabla}^2\vec{E} - \frac{1}{c^2}\frac{{\partial}^2\vec{E}}{{\partial}t^2} = -\frac{1}{{\epsilon}_0}{\vec{\nabla}}(\vec{\nabla}\cdot\vec{P})+{{\mu}_0}\frac{{\partial}^2\vec{P}}{{\partial}t^2}[/tex]
Maxwell's equations:
[tex]\vec{\nabla}\times\vec{E}=-{\mu}\frac{{\partial}\vec{H}}{{\partial}t}[/tex] ...(1)
[tex]\vec{\nabla}\cdot\vec{E}=\frac{\rho}{\epsilon}[/tex] ...(2)
[tex]\vec{\nabla}\times\vec{H}=\vec{J}+{\epsilon}\frac{{\partial}\vec{E}}{{\partial}t}[/tex] ...(3)
[tex]\vec{\nabla}\cdot\vec{H}=0[/tex] ...(4)
[tex]\vec{D}={{\epsilon}_0}\vec{E} - \vec{P}[/tex] ...(5)
In the notes J and [tex]/rho[/tex] did not have the f subscript, but there was a note saying it was dropped for simplicity. In the problem, the f subscripts were there. I am going to assume they are applying directly to the symbols in the Maxwell equations (that [tex]J = J_f and \rho={\rho}_f[/tex]).
My first confusion lies in the fact that when you simplify the Maxwell equations using the two knowns above, you end up with:
[tex]\vec{\nabla}\times\vec{E}=-{\mu}\frac{{\partial}\vec{H}}{{\partial}t}[/tex] ...(1.b)
[tex]\vec{\nabla}\cdot\vec{E}=0[/tex] ...(2.b)
[tex]\vec{\nabla}\times\vec{H}={\epsilon}\frac{{\partial}\vec{E}}{{\partial}t}[/tex] ...(3.b)
[tex]\vec{\nabla}\cdot\vec{H}=0[/tex] ...(4.b)
But using these exact equations and the identity:
[tex]\vec{\nabla}\times\vec{\nabla}\times\vec{E} = \vec{\nabla}(\vec{\nabla}\cdot\vec{E}) - {\nabla}^2\vec{E}[/tex] ...(6),
the homogeneous wave equation is found:
[tex]{\nabla}^2\vec{E} - \frac{1}{c^2}\frac{{\partial}^2\vec{E}}{{\partial}t^2}=0[/tex] ...(7)
So I am kind of confused what I am supposed to be doing here. Did I mess up the assumption and reduce the maxwell equations too much? If not, am I trying to equate the RHS of the inhomogeneous equation to 0? I tried rearrange equation (5) for E, then plug it into the LHS of (1) and got:
[tex]\frac{1}{{\epsilon}_0}{\nabla}^2(\vec{D}-\vec{P})-\frac{1}{{{\epsilon}_0}c^2}\frac{{\partial}^2({\vec{D}-\vec{P}})}{{\partial}t^2}[/tex]
I separated out the terms with D and terms with E in them, using the fact that the operators are linear. And therefore had:
[tex]\frac{1}{{\epsilon}_0}{\nabla}^2\vec{D} - \frac{1}{c^2}\frac{{\partial}^2\vec{D}}{{\partial}t^2}-\frac{1}{{\epsilon}_0}{\nabla}^2\vec{P} + \frac{1}{c^2}\frac{{\partial}^2\vec{P}}{{\partial}t^2}[/tex]and then in the notes, the parts with D equaled 0. It seemed to be a consequence of equation (7), and would just make is so that I had to satisfy the condition: [tex]{\nabla}^2\vec{P}={\vec{\nabla}}(\vec{\nabla}\cdot\vec{P})[/tex]
but I couldn't get that to work out either, using the earlier vector calc identity (equation 6). So basically I am either approaching this wrong, or have made a bad assumption.
Still wondering about this problem..Haven't really worked on it, since I'm kinda stumped.
EDIT: Figured out that one of my initial equations had a slight error. Problem solved!
