Inner Product Space over Fnite Field
The discussion revolves around the properties of inner product spaces, specifically in relation to finite fields compared to real and complex fields. Participants explore the definitions and requirements of inner product spaces and the implications of these definitions on vector spaces over finite fields.
  • Some participants note that inner product spaces are defined over real or complex fields, implying that finite fields do not meet the definition.
  • One participant questions whether a function satisfying the inner product requirements can exist for vector spaces over finite fields.
  • Another participant explains that one requirement for inner product spaces is that the inner product of a vector with itself must be nonnegative, which does not apply in finite fields.
  • A participant references a Wikipedia page to clarify that the base field must contain an ordered subfield for non-negativity to be meaningful, thus excluding finite fields due to their non-zero characteristic.
  • Further elaboration is provided on the concept of field characteristic, illustrating that in finite fields, adding a non-zero element multiple times can yield zero, which contradicts the notion of positivity.
Participants generally agree on the limitations of finite fields in fulfilling the requirements of inner product spaces, but the discussion includes varying levels of understanding and interpretation of the definitions involved. Some points remain contested or unclear, particularly regarding the implications of field characteristics.
Limitations in understanding arise from the definitions of inner product spaces and the characteristics of finite fields. The discussion highlights the need for clarity on how positivity and negativity are defined in different mathematical contexts.
jOc3
I come over this in my coding theory but can't understand it. It says finite fields do not fulfil the definition of inner product space like other fields (R and C. Why? How is the proof? Thanks!
I think it's just part of the definition. An inner product space is a vector space over R or C, by definition.
I don't think that quite answers the question. Is it true that, if V is a vector space over a finite field, then there cannot exist an function VxV-> V satisfying the requirements for an inner product?
Yes, you're right. This wikipedia page on inner product spaces explains it well:
http://en.wikipedia.org/wiki/Inner_product_space#Definition
The explanation is in the remark section of the definition...
One of the requirements of inner product spaces is that <x,x> is nonnegative. But positivity and negativity don't make sense in a finite field.
of course this is just language. various dot products certainly make sense over any field, just not non negative ones.
This is what I get from wikipedia but I can't figure it out. "...it is necessary to restrict the basefield to R & C in the definition of inner product space. Briefly, the basefield has to contain an ordered subfield (in order for non-negativity to make sense) & therefore has to have characteristic equal to 0. This immediately excludes finite fields." How is it "immediately excludes finite field"? Best if an example can be provided along with the explanation. Thanks a lot!
If you have a non-zero element x in a field... And you add it to itself a number of times > 0... for example x is 1 time... x + x is 2 times... then the minimum number of times needed for the sum to be zero is the characteristic of the field... so given x is non zero, x+x is non-zero, but x + x + x is zero... then the characteristic of the field is 3. If there is no such number greater than zero, then the characteristic of the field is defined to be 0.
So suppose a field has non-zero characteristic. Let x be any non-zero element... suppose it's positive... then x + x + x +... = 0 at some point... but this doesn't make sense... for positivity and negativity to make sense... if you have a positive element, and you keep adding positive elements, the result should be positive... not zero.
Take the field Z3 = {[0]3,[1]3,[2]3}
[1]3+[1]3+[1]3 = 0. If [1]3 was positive then the sum would be positive... if [1]3 was negative then the sum would be negative. positive and negative don't make sense here.
In the real or complex number field 1+1+1+... will never be equal to zero. So they have characteristic 0.
Wow! That really answers all my doubt. Thank you!
  • · Replies 18 ·
