Input and output voltages and amps on my laptop's charger
The discussion centers on the specifications of laptop chargers, specifically the input and output voltages and amperages. The new charger for the laptop has an input of 100-240V at 1.5A and an output of 19V at 3.42A, indicating that the charger functions as a transformer. It steps down the higher input voltage from the wall outlet to the lower output voltage required by the laptop. The difference in amperage is explained by the power equation P=IV, which allows for varying combinations of current and voltage to deliver the same power.
  • Understanding of electrical transformers
  • Basic knowledge of voltage (V) and amperage (A)
  • Familiarity with the power equation P=IV
  • Awareness of laptop power requirements
  • Research "how transformers work" to understand voltage conversion
  • Learn about "laptop power management" to optimize performance
  • Explore "power supply specifications" for various electronic devices
  • Investigate "thermal management in electronics" to understand heat generation
Electronics enthusiasts, laptop users, and anyone interested in understanding power supply specifications and transformer functionality.
bluemoonKY
The wire on the charger that came with my laptop eventually frayed, and I had to buy a new charger for my laptop. Both the new and old chargers for my laptop plug into a standard wall outlet. On the new charger, it says the following: " Input: 100-240V ~ 1.5A 50-60Hz Output: 19V --3.42A 65W MAX. "
I assume that the V stands for voltage, and the A stands for amps. But why is there a different voltage for input and output? What is the meaning of input and output? Why is there a different amperage for input and output?
Computer science news on Phys.org
Google "electrical transformers" (your charger is a transformer)
Your laptop needs 19 volts to operate, but your wall socket provides 120 volts. The charger is a transformer that steps down the input voltage so it doesn't damage your laptop. It then outputs this stepped down voltage to your laptop.
The amperage is different because of the way the electronics work. To operate, your laptop needs electrical power. Power is given by the equation P=IV, or power equals current times voltage. This means that you can provide the same amount of power with different currents and voltage as long as their product is the same. Your laptop charger only takes in up to 1.5 amps, but it can supply up to 3.41 amps to the laptop at a reduced voltage. Note that the voltage required by the laptop remains the same during use, but the amount of current drawn by the laptop will change as you use it. If you're doing lots of processor/graphics intensive stuff you will draw more amps than if you just sit there at the desktop.
You can feel when the laptop draws more power by touching the transformer.
As you use more power (which is equivalent to more current) the transformer will heat up.
  • · Replies 28 ·
