Inputting and Ordering Numbers in C
  • Thread starter Thread starter rambo3131
The discussion revolves around writing a C program that takes an uncertain number of numerical inputs and orders them from maximum to minimum. Participants explore various methods to handle input without relying on EOF, as the number of inputs can vary.
  • Homework-related
  • One participant expresses a need for a program that can handle an uncertain count of numbers without using EOF.
  • Another suggests using a terminating character or number in the input to signal the end of data instead of EOF.
  • A participant shares a code snippet that reads numbers until a non-number character is encountered, indicating a potential solution.
  • There is a request for clarification on whether the input will come from a file or the keyboard.
  • One participant mentions using a technique that does not rely on EOF and expresses interest in learning how to use EOF effectively.
  • Another participant provides an example of how to create a file and run the program with input redirection, explaining the use of Ctrl+D to signal EOF when reading from the keyboard.
  • A modified version of a previous code example is shared, which includes error checking for file opening and ensures robust reading of numbers.
Participants have not reached a consensus on the best method to handle input without EOF, as multiple approaches are discussed, and some participants express uncertainty about their understanding of EOF.
Some participants are unclear about the specifics of EOF and how to implement it in their programs. There are also varying levels of familiarity with file handling in C, which may affect the discussion.
Individuals interested in programming in C, particularly those looking to handle dynamic input sizes and learn about file I/O operations.
rambo3131
Hi , I have a question about C. I want to write program that takes numbers as inputs and orders them from maximum to minimum. However, i ve a problem .Count of number is uncertain.I mean ,sometimes i will give the program 5 numbers ,sometimes 10 numbers or another.How can i do this without using eof since i don't know using eof.Please help me ...
Technology news on Phys.org
Sorry ,topic must be taking inputs in C .By the way I use linux.
You have to tell the program when to stop reading from the file. You can make the first entry in the file the number of numbers, use a terminating number or character in the file, or use EOF. If the file is supplied to you, you'll probably need to use EOF. Good luck, rambo3131.
Can you give us the exact wording of the problem? It would help to know this information, which can help determine the direction to go.
The following code will read numbers until unsuccesful.
That will be at EOF or when a non-number character is encountered.
Code:
#include <stdio.h>
void main(void)
    int number;
    while (1 == scanf("%d", &number))
        printf(" %d", number);
Is this what you want?
From a file or from the keyboard?
Thanks for all of you so much! I used " ı like serena" 's technique(without eof) and understood this. Moreover i want to learn about eof ( i think, this eof was important).How can i use eof?.Should i create file ? but i don't know this.Could you give an example code please?
Hi, rambo3131. I think this is correct. It's been awhile.
Code:
#include <stdio.h>
#include <io.h>
#include <stdlib.h>
int main(void)
  FILE *fp;
  int number;
  fp=fopen("test", "r");
// A return value of EOF != 1, so this will terminate on EOF.
while (1 == fscanf(fp, "%d", &number))
   printf("%d", number);
  return 0;
I'm not sure what you do and do not know, so I'll just start somewhere.
EOF means "end-of-file" and if you try to read beyond the end of a file your reading function will act as if the special EOF-symbol has been read.
To create a file you can use e.g.:
$ echo "1 2 3 4" > test.txt
and you can run the program with
$ ./a.out < test.txt
Alternatively you can run your program without a file, effectively reading from the keyboard. You would do that like this:
$ ./a.out
1 2 3 4
Ctrl+D
The Ctrl+D here signals to Linux that you're at the end of your input, which is treated by your program as if the end-of-file is reached.
Is this the kind of stuff you want to know?
yes, Ctrl+D is so useful .Thank you so much.
Besides, ı got your eof example sciurus.thanks a lot :)
I have a slight modification of sciurus' code to make it more robust.
Code:
#include <stdio.h>
int main(void)
   FILE *fp;
   int number;
   fp = fopen("test", "r");
   if (NULL != fp)
      /* A return value of 1 means that 1 number has been
       * succesfully parsed from the input
      fclose(fp);
   return 0;
  • · Replies 49 ·
35K
  • · Replies 17 ·
