Inputting and Ordering Numbers in C
  • Thread starter rambo3131
11 replies · 3K views · last reply
rambo3131
Hi , I have a question about C. I want to write program that takes numbers as inputs and orders them from maximum to minimum. However, i ve a problem .Count of number is uncertain.I mean ,sometimes i will give the program 5 numbers ,sometimes 10 numbers or another.How can i do this without using eof since i don't know using eof.Please help me ...
Sorry ,topic must be taking inputs in C .By the way I use linux.
You have to tell the program when to stop reading from the file. You can make the first entry in the file the number of numbers, use a terminating number or character in the file, or use EOF. If the file is supplied to you, you'll probably need to use EOF. Good luck, rambo3131.
Can you give us the exact wording of the problem? It would help to know this information, which can help determine the direction to go.
The following code will read numbers until unsuccesful.
That will be at EOF or when a non-number character is encountered.
Code:
#include <stdio.h>
void main(void)
    int number;
    while (1 == scanf("%d", &number))
        printf(" %d", number);
Is this what you want?
From a file or from the keyboard?
Thanks for all of you so much! I used " ı like serena" 's technique(without eof) and understood this. Moreover i want to learn about eof ( i think, this eof was important).How can i use eof?.Should i create file ? but i don't know this.Could you give an example code please?
Hi, rambo3131. I think this is correct. It's been awhile.
Code:
#include <stdio.h>
#include <io.h>
#include <stdlib.h>
int main(void)
  FILE *fp;
  int number;
  fp=fopen("test", "r");
// A return value of EOF != 1, so this will terminate on EOF.
while (1 == fscanf(fp, "%d", &number))
   printf("%d", number);
  return 0;
I'm not sure what you do and do not know, so I'll just start somewhere.
EOF means "end-of-file" and if you try to read beyond the end of a file your reading function will act as if the special EOF-symbol has been read.
To create a file you can use e.g.:
$ echo "1 2 3 4" > test.txt
and you can run the program with
$ ./a.out < test.txt
Alternatively you can run your program without a file, effectively reading from the keyboard. You would do that like this:
$ ./a.out
1 2 3 4
Ctrl+D
The Ctrl+D here signals to Linux that you're at the end of your input, which is treated by your program as if the end-of-file is reached.
Is this the kind of stuff you want to know?
Besides, ı got your eof example sciurus.thanks a lot :)
I have a slight modification of sciurus' code to make it more robust.
Code:
#include <stdio.h>
int main(void)
   FILE *fp;
   int number;
   fp = fopen("test", "r");
   if (NULL != fp)
      /* A return value of 1 means that 1 number has been
       * succesfully parsed from the input
      fclose(fp);
   return 0;
