Instaneous Power in a standing Wave
17 replies · 10K views
TFM
The instantaneous rate at which a wave transmits energy along a string (instantaneous power) is
[tex]P(x,t) = =F\frac{\partial y(x,t)}{\partial x} \frac{\partial y(x,t)}{\partial t}[/tex]
where F is the tension.
Show that for all values of x, the average power [tex]P_a_v[/tex] carried by the standing wave is zero. (Equation [tex]P_a_v = \frac{1}{2}\sqrt{\mu F} \omega^2 A^2[/tex] does not apply here. Can you see why?)
[tex]P(x,t) = -F sin(A_S_W(\omega t)kA_S_Wcos(kx))(A_S_Wsin(kx)\omega cos(\omega t))[/tex]
^ Power equation calculated from part 1
The answer section is in the form of a writing box (I am using Mastering Physics), Not the normal maths box.
What is the best way to show for all values of x the power is zero?
TFM
Does anyone have any idea what the best way is to approach this question?
Would be grearly appreciated,
TFM
This is the annoying part of Mastering Physics - I can't get onto the next question until I finish this one. What I would normally do for a "Show that for all values of x..." question, I would just stick in thousands of values for x.
As you can see, any ideas would be very greatly appreciated.
TFM
What is the best way to go about this question, should I just use a lot o different values, or is there a way to change the equation into an average one?
ANy help would be greatly appreciated,
TFM
Given the instantaneous power, find the time average. What's the average value of [itex]\sin\omega t[/itex] or [itex]\cos\omega t[/itex] over a complete cycle?
Since the maximam value is 1, the minimum is -1, the average will be 0.
Would you insert this intop the orginal power equation?
TFM
I don't quite understand your instantaneous power equation. Can you check for typos? If you can write it as [itex]P(x,t) = f(x)\cos\omega t[/itex], then you can immediately see that the average is zero since the average of sin or cos is zero (they are negative as much as positive).
If cos(average) = 0, then it will make the average power 0 becasue all the terms are multiplied together, so the 0 from cos(average) and sin(average) will make the whole equation = 0.
The equation is right, because I calculated it for the first part oif the question, on Mastering Physics, and it came up as it correct.
TFM
edit:
It will make the formula:
[tex]p_a_v_g = -F*(0)[/tex]
You cannot independently average different factors. You must average the entire function of t as a whole. You can show that [itex]\sin\omega t \cos\omega t[/itex] can be written as a simple sine function and thus its average must be zero.
Your equation in post #1 as you wrote it here:
doesn't quite make sense to me. (You've got some parentheses mixed up or something.)
The equation from Mastering Physics:
[tex]P(x,t) = -F (sin(\omega t)kA_S_Wcos(kx))(A_S_Wsin(kx) \omega cos(\omega t))[/tex]
TFM
That's better.
Now you can write that equation as [itex]P(x,t) = f(x) \sin\omega t \cos\omega t[/itex]. Then show that the sine*cosine factor is equivalent to a simple sine function and thus averages to zero.
Rearranging the equation, then:
[tex]P(x,t) = sin(\omega t)cos(\omega t)[-F(kA_S_Wcos(kx))(\omega A_S_Wsin (kx))][/tex]
do I need to use doubke angle functions to show that the sine*cosine factor is equivalent to a simple sine function?
TFM
That's what I would do. :wink:
Should I use:
[tex]sin2\theta = 2sin\theta cos\theta[/tex]
rearranging:
[tex]\frac{sin2\theta }{2} = sin\theta cos\theta[/tex]
Inserting into the equation, giving:
[tex]P(x,t) = \frac{sin2\theta }{2} F_x[/tex]
where [tex]F_x[/tex] is the other half of the equation
TFM
I meant
TFM
(I tried editting, but it didn't change)
[tex]P(x,t) = \frac{sin2\omega t}{2} F_x[/tex]
What would be the best thing to do now?
TFM
Declare victory! Assuming that you accept that the average value of sin(t) = 0, you're done.
