Instantaneous angular speed question
Erenjaeger
How do you calculate instantaneous angular speed?[/B]
I have been told that it is when delta t approaches 0, so its just the derivative of delta theta over delta t.[/B]
does it involve tangent line like normal instantaneous velocity ?
[/B]
You are on the right track involving derivatives. See below.
I have been told that it is when delta t approaches 0, [/B]
Yes, this is true.
(I'm making a few assumptions about [itex]\theta (t)[/itex] not having a discontinuity at the point of t in question. But for simplicity sake, I'll just say, "yes, that's true," which it is for most cases.)
Be careful here. It is not the derivative of [itex]\frac{\Delta \theta}{\Delta t}[/itex]. Be careful of your wording there.
Rather, the instantaneous angular velocity [itex]\omega (t)[/itex] is the derivative of [itex]\theta (t)[/itex] with respect to t (not "over [itex]\Delta t[/itex]").
Making the stipulations about smooth functions (not having discontinuities and so forth),
[tex]\lim_{\Delta t \rightarrow 0} \frac{\Delta \theta}{\Delta t} = \frac{d}{dt} \{ \theta (t) \} = \omega (t)[/tex]
does it involve tangent line like normal instantaneous velocity ?[/B]
That question has a simple answer, but I'll let you ponder that. If you objectively know the behavior a variable or function, say [itex]\theta(t)[/itex] which changes as a function of time, what is the instantaneous rate of change of that function? What is the derivative of a function?
