Intake manifold for turbo applications
Designing an intake manifold for a turbocharged 1.6L engine involves considerations of plenum versus tube designs. A D-shaped plenum can build pressure but may introduce lag, while a header-style intake could improve spool time but might compromise top-end power due to volume limitations. The discussion highlights that pressure in turbo applications can equalize flow issues, making the intake less critical than the exhaust system. Aftermarket intakes often feature larger plenums to balance airflow and torque characteristics, with shorter runners enhancing low-end torque and longer ones favoring top-end power. Understanding these dynamics is essential for optimizing performance in turbo applications.
limit less
Hello all, this is my first post on this site, so I'll try not to look stupid.
I am currently trying to design a new intake manifold for a turbo 1.6L engine. I have never attempted to this before, but I have a few ideas in mind, and would like some feedback. First, I could use a D-shape pipe for a plenum, and just straight pipe it to the head. My second thought is to use a turbo exhaust manifold, which has even length pipes to each cylinder, and modify it to fit the intake.
The thing I am wondering is why every other turbo car uses a plenum style intake instead of a tube design. I understand that the plenum allows a build up of a pressure, but does it then not take longer to pressure up? If you used a header type intake, would it spool up extreemely then? Would you lose top end power because of a volume issue, or would the better, more even flow of air compensate for this.
Sorry the post is so long, hope that someone has an answer or two for me.
Does anyone have any help for me? Perhaps someone with fluid mechanics knowledge.
just an old hot rodder
but the intake is less important on a turbo
as the pressure is a great equalizer and if you want more flow crank up the boost
pipe size and shape goes away with pressure
ext both before and after the turbo is where the gains are to be made
inc the whole ext pipe system you can't go too big there
Thanks for the reply, but why do all of the aftermarket intakes use a large plenum and then use runners of of that? I was reading another post on this site that said that the larger the plenum, the longer the lag, and the shorter the runners, the more torque and less top end you get and vise versa. Just wondering why?
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
