Integers 0-9999999 containing 2 3's and 2 5's
  • Thread starter Thread starter SneakyArab
    Integers
The problem involves counting how many integers from 0 to 9,999,999 contain exactly two digits of 3 and two digits of 5, with the remaining digits being filled by other digits.
  • Exploratory, Assumption checking
  • Participants discuss the total number of possible integers and the method of selecting positions for the digits 3 and 5. There is an exploration of how to account for the remaining digits and the arrangement of all digits.
Participants are actively engaging with the problem, with some providing insights into the counting process and others questioning the accuracy of the initial attempts. There is a recognition of the need to avoid overcounting arrangements.
There is a mention of the total number of digits being 7 and the specific requirement of having exactly two 3's and two 5's, with the remaining digits needing to be filled from a limited set of options.
SneakyArab
How many integers from 0-9,999,999 have exactly two 3's and two 5's as digits.
I'm not really sure...
The answer is 107520, if I'm not mistaken. I made a program to count it up for me, so I'm fairly sure that that is the correct answer. I'm just trying to figure out how to do it manually now.
So I know there are 7 digits, 4 of which are 3, 3, 5, 5, and the other 3 are 0,1,2,4,6,7,8,9.
So the remaining 3 digits each have 8 possibilities. So there are 8^3 different combos for the other 3 digits. But then all of the digits can be rearranged, so I thought it would be 7! * 8^3. That was not even close to correct.
Well, each of the 7 digits can be any digit from 0...9. So we have the numbers
0 0 0 0 0 0 0
0 0 0 0 0 0 1
9 9 9 9 9 9 8
9 9 9 9 9 9 9
Clearly, there are 10^7, or 10 million, of these.
So, you have to pick 2 from 7 to call "3". Then you have to pick 2 from the remaining 5 places to call "5". Then you can choose any of 8 digits to fill the last three spots.
If you use this information, you WILL get the right answer. If I were to do the next step, you would get the answer. That's how close you are now. Focus on the logic I used and understand that, as that's what's most important.
Not all rearrangements give rise to different numbers. You are over counting. First pick two positions out of the 7 to place the 3's. How many ways to do that?
Ooooh ok, I see.
so its 7 choose 2 * 5 choose 2 * 8^3
Thank you so much!
  • · Replies 22 ·
  • · Replies 19 ·
